Re: Help with Locating Disks with Vision
The steps: Acquire image Convert it to HSV (hue, saturation, and value) (Binary) Threshold image to locate only the desired colour (red, white blue) This is where vision programming has a lot of diversity... We found the contour of an image, that is, where black meets white. Approximate a polygon (I promise I will make this better before next build season for squares for teams that want to do pose) then I said if (result > 5)) [ it's a circle; } result being the amount of sides of the contour. From then, you ideally should have located the circle. To find the center: // Calculate the moments to estimate the position of the frisbee CvMoments *moments = (CvMoments*)malloc(sizeof(CvMoments)); cvMoments(*yourcontourhere*, moments, 1); // The actual moment values double moment10 = cvGetSpatialMoment(moments, 1, 0); double moment01 = cvGetSpatialMoment(moments, 0, 1); double area = cvGetCentralMoment(moments, 0, 0); posX = moment10/area; posY = moment01/area; This gives subpixel accuracy for the center Now you have the center of a frisbee based off the specified colour. Congrats. BUT, what if there was more than 1 of the same coloured frisbee? This simple algorithm solves this problem (keep in mine that I used opencv and changed the center from the top left to the center of the screen to make the logic easier) Int prevclosestfrisbee = 300 (arbitary pixel value that is high on the screen. *note the greater the y pixel value, the further it will be away.) if (frisbee.y < prevclosestfrisbee) { prevclosestfrisbee = frisbee.y } else { contours = contours ->h_next: } after you go through all the contours (the frisbees that passed the threshold test and the approximate polygon test, then you're left with one with the lowest y value. **note, you can do this with all 3 coloured frisbees, I posted an image on here of a frame while tracking all 3 disks. It does take a fairly large amount of processing power (this program ran ~13 fps while the program that tracked the alliance wall ran at ~27, but it is do able!) Hope this helped! |
