Go to Post If Andy asked y'all to stand on your head, would you do that, too? ;) - Madison [more]
Unread 07-08-2013, 18:46
sarah_storer's Avatar
sarah_storer sarah_storer is offline
Georgia Tech RoboJackets Outreach
AKA: Sarah Storer
FRC #5332 (Toaster Tech)
sarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to behold
Question Connectivity Issues
When I try to connect to the robot with my computer via wifi connection the communications and robot code LEDs on the driver station do not turn green
Messages in the diagnostics section are attatched.
The settings on the D-Link are as follows:
switch set to AP 2.4GHz
power is correct
CRio plugged in via ethernet cable
Camera plugged in via ethernet cable
Then I tried plugging straight into the cRIO with an ethernet cable and every 4 seconds or so the message on the diagnostics section of the driver station switched from cRIO(.2)-GOOD to cRIO(.2)-bad
When I plugged straight into the DS Radio, via Ethernet cable as well, it didn't improve the connection situation either.
I can not see why it does not work
If anyone can help I would be very greatful!
TEAM 3753 BULAH BOTS ALUMNI
2012-2015: Code, pneumatics, and electrical for BULAH BOTS Team 3753
2013: Bayou Regional 1st seed alliance captain and regional winners (With 118 and 4589)
2014, 2015: Bayou Regional semi-finalist
2016-?: Mentor for TOASTER TECH Team 5332
2016: Columbus District 3rd seed alliance captain, semi-finalist; Kennesaw District 3rd seed alliance 1st pick, semi-finalist; Peachtree District State Championship 4th seed alliance captain, quarter-finalist, Industrial Design Award, World Championship qualification
Unread 07-08-2013, 18:57
Re: Connectivity Issues
I'd suggest starting with as simple a setup as possible and get that working before adding extra devices into the mix.
That means connecting your laptop directly to the cRIO and debugging that connection first.
The obvious things to check are:
  • Turn off any Firewalls or anti-virus that may be running on the laptop
  • Fireup the Driver Station app and check that it is allowed to change the IP settings automatically. (See the Setup tab).
  • Verify that the team number on the Setup tab is correct.
  • After the Driver Station sets the IP addresses, directly verify that they are correct. (Control Panel -> Network Connections -> adapter settings)
  • You can also bring up a CMD prompt window and verify your network settings with "ipconfig /all" . Then use "arp -av" to see what shows as connected to your laptop.
Once that works reliably connect via Ethernet through the DLink and that should work identically.
Once that's confirmed you can try wireless between the laptop and the DLink.
  • Does the DLink wireless network show up on your laptop's list of available wireless networks?
  • Can you manually connect to the DLink SSID from the laptop?
Unread 07-08-2013, 19:03
Have you previously run your robot since your last event that used FMS?
If you have not, I suspect you may have forgotten to reset the security on the radio. If you have, disregard this question.
Unread 07-08-2013, 19:40
AKA: Sarah Storer
I have run it...but I have no idea what you mean by resetting the security
Unread 07-08-2013, 19:53
At events, the router is set up for operation with the field. Each robot has its own "key". Often, after an event, teams will forget to shut the "key" off for home-field running. This takes a couple minutes and a reset of the security settings.
Seeing as the robot has been run since the last event it was at, though, this isn't the issue.
Unread 07-08-2013, 23:02
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Could you elaborate on how exactly to do this, or at least link me to a place that explains how. I'm definitely breaking the search before I post rule, but my team just spent 3 hours tonight trying to connect to our robot and I would appreciate it if you made my life a little easier.
Unread 08-08-2013, 00:36
Nathan4567a's Avatar
Nathan4567a Nathan4567a is offline
Circuit Master
AKA: Nathan Lerner
FRC #2587 (Discobots)
Nathan4567a will become famous soon enoughNathan4567a will become famous soon enough
Make sure the router is not in bridge mode. If its not, see if a ping works. Also try and reset the router.
Computer-Builder.Photographer.Videographer.Nerd
Unread 08-08-2013, 01:09
Sorry, but I'm a mechanical guy. I've seen it done, and with coaching helped to do it in a pinch, but I've never done it and don't know where the documentation is (but I'm willing to bet that a CD search about "WPA key" or somesuch phrase will turn up something). Should be a few pretty recent ones--every year someone forgets.
Unread 08-08-2013, 08:46
One of the tools that FIRST gave us this season is the
2013 FRC Bridge Configuration Utility
If you already have it, then a shortcut was probably added to your desktop.
Just connect the DLink to your laptop via Ethernet, run the utility and follow directions.
There are also written directions in Getting Started with the 2013 Control System beginning on page 23.
or
Screensteps: Programming your Radio for Home Use
Unread 08-08-2013, 09:00
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
You might have to do a hard reset of the bridge.
Originally Posted by Bridge Manual
To reset the access point, locate the reset button (hole) on the rear panel of the unit. With the access point powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the access point will go through its reboot process. Wait about 30 seconds to access the access point.
Make sure the bridge is powered on completely. It can brick if you don't wait to reset it.
Unread 08-08-2013, 15:27
AKA: Sarah Storer
Alright I just got into the shop to work on our robot and the wifi started working when I unplugged the camera! I think it has something to do with the IP address or something...I'll look into it.
To the guy that is having connection issues like me: make sure you just start with the basics...if you're having issues try to unplug any accessories (like the camera) from the DS Radio
Good luck and I'll keep you all updated!
Unread 08-08-2013, 21:44
Pault's Avatar
To everyone who responded to me, thank you so much. I have gotten wireless communication between the driver station and the CRIO. Unfortunately, I've been working on this from my house using an empty CRIO and a router running off a power outlet, and because I don't have an analog breakout board attached NetBeans won't let me upload code and test it out. I will be getting to a robot on Monday, so I should be able to confirm everything works then.
Here's my new question: how do I change the SSID of the router. I know before the SSIDs on our robots used to be 3958_ROBOT_NAME, but now its just 3958. I imagine this would get confusing when there are multiple robots going at the same time. I have tried putting the IP address into my browser, but chrome is just saying that the webpage is not available.
Unread 08-08-2013, 23:08
The SSID doesn't really matter for at home use, but you have to be able to connect and browse to the DLink to change it to something else.
Since you are unable to browse directly to the router (and I assume you've connected them by wire or wireless), that probably means that your laptop and router do not have compatible IP addresses and netmasks.
Interestingly enough the DLink & laptop don't require compatible IP addresses unless you want to browse specifically to the DLink.
You can use the Radio Config utility I mentioned earlier if the router is one of the 1522 DLinks. The utility will change the SSID to your team number as well as set the router IP/netmask correctly. It will do so by changing the laptop IP/netmask to be compatible with the DLink in either it's factory default or FRC standard settings.
Or you can browse to the DLink or third-party router manually and change the router settings by hand, by resetting the laptop IP to match what you think the router settings are. For instance, if you think the DLink has an IP address of 10.39.58.1 then make sure your laptop IP address is 10.39.58.5, so they are in compatible IP ranges.
If however, the DLink is using a factory default IP address (192.168.0.50), then you will have to make your laptop IP 192.168.0.5 (and browse to the default IP address of course).
Unread 15-08-2013, 11:01
AKA: Sarah Storer
Our connectivity works now!
It turns out that when I went to set up our camera I accidentally changed the IP address of the DS Radio to the camera. As a result, the computer was trying to find the signal in the camera...so it didn't work.
I was able to go and correct this and then it connected!
Thanks everyone for your help
