Go to Post Publishing your code and designs = good. - MrRoboSteve [more]
Unread 07-08-2013, 21:20
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
Re: Upside down Frisbees; can your team get them out?
I was going to start a thread about upside-down discs, but remembered to search. Then I found this one. And decided to revive it.
Other than the teams mentioned, can you shoot discs upside down? Do you have a mechanism to flip them around/eject them?
My team can't shoot them upside down and doesn't have a way to get them out. We can try flipping the robot to get them out, but it hasn't worked if my memory serves me correctly. (happens within the first minute of teleop)
Also, could you describe why it doesn't shoot correctly? Ours has something to do with the mechanism that pushes our discs into our wheel, it can't catch the edge of it properly.
J Wallace IV
Truck Town Thunder
Just a college student now.
Unread 07-08-2013, 21:36
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Upside-down discs jam our shooter-loader piston and we have no way to eject them. Our floor pickup, however, will not pick them up.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 07-08-2013, 23:21
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Our shooter is incompatible with upside-down discs. Our feeding mechanism, a shark fin shape actuated by a pneumatic cylinder, is designed to stay low and catch the bottom edge of discs that it feeds forward while also being able to slide backward when the next discs falls into place without snagging them. Unfortunately, its low profile means that it doesn't catch the rounded edge of upside-down discs and instead slides right under them.
After spending a season watching our offensive capabilities end during matches because of upside-down discs in our hopper we finally decided to add a flipper during IRI. We finished adding a 2 inch stroke pneumatic cylinder beneath our shooter with 2 matches to go. We inadvertently mounted the cylinder at a slight enough angle that it doesn't just push the discs up but, instead, flips them over.
We never used it during a match.
FIRST Team 1732- Hilltopper Robotics
Website, Facebook, Twitter, Instagram
Robotics Association at UW-Milwaukee
Website, Facebook
Unread 07-08-2013, 23:27
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
At one point in time, our floor pickup could pick up upside down disks. Since then its been changed and somewhere along the lines it started rejecting them. However, once they are in, we have no problems jamming (because we don't stack frisbees, we store them in a line) and can shoot them exactly the same way as normal frisbees. We also mechanically have the ability to differentiate between right side up and upside down, but we never put it to use in code. All of this is possible because of a flange sticking out of the middle of our frisbee path which forces regular disks to be flat on the floor and upside down ones to be pushed up against the ceiling.
Unread 08-08-2013, 07:10
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Since we use an air cylinder shaft to catch the lip of the disc to send it on its way we, at first, could not eject an inverted disc.
After BMR I came up with the L.I.F.E. wedge.
Little
Inverted
Frisbee
Ejector
It pushes the inverted disc into the shooting wheel and ejects it. The disc doesn't fly far but it comes out screaming. At CRR we ejected an inverted disc at out opponents plexiglas and scared the #@*% out of them
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 08-08-2013, 12:48
Andrew Lawrence
Posts: n/a
Little
Inverted
Frisbee
Ejector
Could you post some pictures of the L.I.F.E wedge, and maybe video of matches where it can be seen being used?
Unread 08-08-2013, 14:40
Chris is me's Avatar
AKA: Pinecone
We human load, so we really didn't care to test it or anything. If an upside down disc ends up in the shooter, someone seriously messed up.
I imagine it could probably clear since we just push the disc from behind. Probably wouldn't fly well though.
Unread 09-08-2013, 00:58
donkehote's Avatar
donkehote donkehote is offline
Design/Manufacture/Strategy Mentor
AKA: Kevin
FRC #5031
donkehote is just really nicedonkehote is just really nicedonkehote is just really nicedonkehote is just really nice
1310 had this issue all the way up until after the first match at champs. That was the only qual we lost, as we jammed at about the 1:40 mark, and ended up loosing by 2 points. Had it not been for that jam, we would have had #1 seed on curie, and things on that field would have been totally different.
http://www.youtube.com/watch?v=rfqeoMx0GeI
4814 pushes us into an upside down disk, then the wall. we normally cant pick up upside down ones, but with the walls help it went in at 1:36. it has difficulty going through the pickup, but makes it out the top from 1:36-1:39. we fire the 2 disks we picked up before that, then we jam for the rest of the match. If you cant tell, i have watched this match in detail multiple times to see exactly how it happened.
First a little background.
Our hammer (the part that pushed the Frisbee into the wheel) engages the outer edge of the Frisbee, and is powered by a spring out, air in piston. our hammer is a bent piece of 1.5" wide, 1/16th aluminium. The bend on the top was just enough to lift an upside down Frisbee, as it impacts right at the curve. this would cause our robot to be a glorified "dishwasher" as our students called it. We came up with the solution before champs, but reluctant to change things, we didn't implement it, as it had only happened once or twice all season. It was such a simple fix, and i bet it would work for any team with this issue and an external hammer.
The solution? A self tapping screw at the right height through our hammer. It is sharp enough to catch the rounded edge of the Frisbee, and eject it. the first time we tried it, it was magic. consistent ejection of upside down Frisbee's at a minimal weight gain. The screw needs to be for wood, as the tip is sharper.
Unread 15-08-2013, 14:28
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
We have had minimal issues shooting upside-down discs. Once, an upside-down disc melted a piece of thin lexan that prevents misfires. Another time, it just ejected and fell out of the shooter right in front of the robot. The third time(at IRI) It went just like any other disc. Take a look at 1592's bot- they actually shot them upside down intentionally. They were the only team I saw all year who tried to do that.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 15-08-2013, 14:32
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
The bot preferred to pick them up upside down because the loader would flip them over before it shot but picking them up upside down or right side up didn't matter because it could gather and shoot both ways.
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 15-08-2013, 14:45
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
During build season, I was designing a flipping mechanism in the conveyor system and it worked flawlessly. However due to size constraints in our chassis we had to scrap that design. :/ For our shooter on the other hand if there is an upside down frisbee in there we are doomed for the rest of the match and are forced to play defense.
Team 696 2010-2013 Student
2014 2x Industrial Design Award Winners CVR and LAR
2013 Inland Empire Finalists -696 Circuitbreakers, 3476 Code Orange, and 4140 Wired
Unread 16-08-2013, 13:47
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Our hopper is incompatible with inverted disks. They don't seem to settle right in the bottom. The shooter will shoot them, its just a matter of moving the disk the .5 inch from the hopper to the shooting wheel. We can sometimes accomplish this by running into the wall at a high rate of speed (how we cleared most jams actually) XD
This, fortunately, didn't happen too many times. We only human fed. The single time it did happen was during a practice match when we wanted to see what happened.
Edit: Obligatory 300th post edit
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 19-08-2013, 23:19
sarah_storer's Avatar
sarah_storer sarah_storer is offline
Georgia Tech RoboJackets Outreach
AKA: Sarah Storer
FRC #5332 (Toaster Tech)
sarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to behold
We actually can't eject discs....and I really wish we could...once we get an upside down one we're done...time to go hang on 10pts. :/ Thankfully that's only happened three times during matches!
TEAM 3753 BULAH BOTS ALUMNI
2012-2015: Code, pneumatics, and electrical for BULAH BOTS Team 3753
2013: Bayou Regional 1st seed alliance captain and regional winners (With 118 and 4589)
2014, 2015: Bayou Regional semi-finalist
2016-?: Mentor for TOASTER TECH Team 5332
2016: Columbus District 3rd seed alliance captain, semi-finalist; Kennesaw District 3rd seed alliance 1st pick, semi-finalist; Peachtree District State Championship 4th seed alliance captain, quarter-finalist, Industrial Design Award, World Championship qualification
Unread 19-08-2013, 23:20
AKA: Sarah Storer
[quote=Garrett.d.w;1287607]The shooter will shoot them, its just a matter of moving the disk the .5 inch from the hopper to the shooting wheel. We can sometimes accomplish this by running into the wall at a high rate of speed (how we cleared most jams actually) XD
/QUOTE]
Running into the wall is an interesting way to do that!...noted
Unread 23-08-2013, 16:28
gabrielau23's Avatar
gabrielau23 gabrielau23 is offline
FRC #2537
gabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nice
We eject them out of the side using our normal shooting mechanism. We've never had to do it since we human load, but we included it just in case our human player screwed up anyway.
The higher I go up, the the faster the best times in my life (like build season) pass...so sad.
