Go to Post And then you realize...If you hadn't been working ALONGSIDE those engineers... you'd never have that other person to say, "Well, why don't you do this, so that it works?" - Nikhil Bajaj [more]
Unread 03-02-2003, 19:09
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Cool Gyro Output Data
The output data from our gyro is in voltage (0-5v), which corresponds to an angular velocity (deg/s). The data is in an analog(ue) format, and thus is unusable in raw form to any custom microcontroller, such as the BS2p we are using. So, we are passing the data to an 8-bit ADC, and then using multiplication (deg./s * sec) to get an angular displacement. Is there any way this can be done before the data hits the ADC, as in a analog(ue) circuit capable of multiplying the gyro output by time, or taking the integral of angular velocity?
I read something about an op-amp capable of integrating, and heard about RC integrator circuits, but I an unable to find anything of use. If u know anything which can help me here, please respond....
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 03-02-2003, 21:34
Go to DigiKey's home page, type multipliers, click on search, and select analog multipliers. The prices will refresh you.
But....
Multiplying is the process of repeated addition. Why not add up everthing greater than 127 (or 128) and subtract everthing below that figure. keep track oh the total, it will be in (turn-rate)*seconds, but the time will be in 26 ms units.
If you actually need to know the heading in degrees, let the Stamp multiply (or divide) this total for you.
Think of it as digital integration. Or is that integer-ation .
Competition Scouting pauluffel Scouting 31 09-01-2003 00:34
Robot Scouting Database archiver 2001 10 24-06-2002 03:00
Limiting PWM in pbasic archiver 2001 4 24-06-2002 00:38
Possible Configuration to keep things cheap archiver 1999 8 23-06-2002 23:03
Distribution of data soap108 Scouting 4 24-12-2001 09:23
