Go to Post It's good to hear I'm not nuts. - sanddrag [more]
  #46   Spotlight this post!
Unread 07-08-2013, 21:28
whophil whophil is offline
whophil is an unknown quantity at this point
Re: Team 67's incredible shooter
I just stumbled across this very informative thread. Adam, have you guys experienced any problems with side loading of the 550 motors? I'm looking to set up some Banebots RS-775 motors in a similar belt drive configuration with the pulley cantilevered on the shaft, but had some doubts about how the motor's internal bearings would hold up over time. (The 775 motor only has a 7.6 mm long shaft, which is another problem in itself...)
Cheers,
Phil
Last edited by whophil : 08-08-2013 at 00:44. Reason: added units for shaft length
  #47   Spotlight this post!
Unread 07-08-2013, 22:23
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Originally Posted by whophil View Post
I just stumbled across this very informative thread. Adam, have you guys experienced any problems with side loading of the 550 motors? I'm looking to set up some Banebots RS-775 motors in a similar belt drive configuration with the pulley cantilevered on the shaft, but had some doubts about how the motor's internal bearings would hold up over time. (The 775 motor only has a 7.6 long shaft, which is another problem in itself...)
Cheers,
Phil
No problems to date with any of the motors we used on either the practice bot or the competition bot. We tried to take special care to not over load the motors with excessive tension on the belts.
I would guess that a 775 would be even more robust to a setup similar to ours.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
  #48   Spotlight this post!
Unread 07-08-2013, 22:52
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Originally Posted by Adam Freeman View Post
Our drawings and CAD models are so crude, it would be pretty embarassing to show them to anyone. But, I'll see what I can find.
-Adam
That's very interesting to me. I've always seen detailed CAD as the mainstay of every highly competitive team, and I'm interested in how a multiple time Einstien winner can perform extremely well and not do a detailed robot CAD.
For instance, how did you know that your climber could grab levels correctly, that nothing would break under stress, that screws would clear other parts, that there would be enough room for electronics or other mechanisms, or that you'd be under weight? Frankly, I don't think I could design a robot without detailed CAD. Things are so many times different sizes than we think them to be that simply fitting everything together would be a huge challenge, at least for me.
Can you shed a little light on your design process?
-Plutarch
  #49   Spotlight this post!
Unread 08-08-2013, 10:21
Forever HOT!
I would say that a detailed CAD process is the rule to follow, but there are always exceptions. When it comes to our design process, we are not the model that should be emulated. The designs that come from our process...maybe. But, the actual process...no!
We have two main designers, myself and Jim Meyer. Our robot is designed 99% in 2D AutoCAD. I sometimes use Solidwork to model already designed parts, but almost never for the design process itself.
Our 2D drawings are very much like very detailed sketches. Almost all the components are sketched out in an assembly view, but the very fine details are usually put in the print sent to the machine shop, and not in the assembly view. So our CAD files are almost impossible to decifer unless you are the designer currently working in the sketch.
Since we have full access to a water-jet machine, we try to design the majority of our parts to be manufactured that way. Since we only need a 2D file to export to the water-jet, it works out that we do all of our design in AutoCAD.
From a strength or weight analysis, our process is very experience oriented. We are confident in our abilities to estimate how small or large a part needs to be to survive in a FIRST environment. Along the same lines, we try to re-use similar designs for the frame, wheels, etc... so we usually know if a part or assembly is going to put us over for weight.
This style of design relys heavily on the designers to be completely involved in the manufacturing and assembly of the parts. Since they are really the only ones that know exactly how the parts are designed to work together.
As I said above, it's not a process that should be copied by anyone. We have made attempts to streamline the process...or add in aspects of other peoples design process (148, 1114, 254, etc...). But, every time when things start getting tight for time during the build season, the process reverts right back to where it has always been.
At this point, we have pretty much accepted that, like it or not, this is who we are...and how we operate.
The time we have to work on our designs seems to be getting less and less each year (between family and work responsibilities), so we don't do much more than is required to get the parts machined and assembled.
We are in the process of adding some more mechanical/design mentors that hopefully will help improve our process and provide more time to further enhance our designs and be able to teach more students/mentors how we create our parts.
-Adam
  #50   Spotlight this post!
Unread 08-08-2013, 10:30
-Adam
In a way, this is one of the coolest posts I've read on CD.
I definitely agree that detailed 2D design work can be used to figure out the geometry of a design (I always think back to the 2D drawings of Simbot SS) but doesn't it get difficult to make iterations, even with a practice bot and the district model?
Thanks for the insight!
  #51   Spotlight this post!
Unread 08-08-2013, 11:33
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Thank you very much! A very interesting read.
-Plutarch
  #52   Spotlight this post!
Unread 08-08-2013, 16:11
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Our nominal pyramid and autonomous shot was around 20-21 degrees. Any time we lost our position of the potentiometer, we would use a digital inclinometer to adjust the autonomous shot back to 20 degrees, then make fine adjustments from there.
Adam,
The digital inclinometer seems really nifty, do you have a part number for this guy?
Thanks!
R.C.
MadTown Robotics Team 1323
  #53   Spotlight this post!
Unread 08-08-2013, 17:05
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Originally Posted by R.C. View Post
Adam,
Thanks!
In a pinch most smartphone platforms have inclinometer apps.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
  #54   Spotlight this post!
Unread 08-08-2013, 18:53
Forever HOT!
Originally Posted by Akash Rastogi View Post
...but doesn't it get difficult to make iterations, even with a practice bot and the district model?
Yes and no. I usually find it's a lot easier to copy over a bunch of lines in an AutoCAD drawing and cut/trim/modify a current design to a new iteration that I do trying to adjust a solid model or assembly. But, that could be b/c I use AutoCAD a lot more than I do Solidworks. It does take a lot more concentration to make sure all the little details are carried over to new drawing or sketch.
...do you have a part number for this guy?
I'll have to stop by the shop and look at the brand we have, but it was very similar in design to this one.
http://www.amazon.com/Digital-Inclin..._sim_sbs_hi_14
If you didn't have one around, I would say a cell phone with an inclinometer app would be just as useful for the level of accuracy we were trying to hold. We just opted for the digital inclinometer b/c the shop had one we could borrow.
-Adam
  #55   Spotlight this post!
Unread 09-08-2013, 09:46
Brandon Holley's Avatar
-Adam
Yep. The trusty "Level" app on my iPhone was THE measurement device used to set our shooter angle. We used the same app on the same phone through our many iterations of shooter to try and get fairly accurate results.
If the shooter was set to the proper angle (27 degrees I think?) we had no issues with scoring.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
  #56   Spotlight this post!
Unread 15-08-2013, 09:51
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
-Brando
You must have quite the level app on your phone. Actually, considering how accurate your bot was, that is really surprising. We used a phone level app to get our shooter dialed in, but it just wasn't accurate enough to get us aligned to the 3 pointer.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
  #57   Spotlight this post!
Unread 15-08-2013, 10:14
So this is kind of one of those funny measurement things. Do you really care what the absolute angle of your shooter was? No, probably not. What you cared about was A. the frisbee going into the goal and B. the shooter being in that same spot everytime.
For this, the app on my phone gave a very repeatable result for us. The actual angle it was measuring was probably not extremely accurate, but we didnt care. We knew what number the app spit out that put the discs in the goal. The consistency came from a very heavily iterated shooter design (we built 8 complete shooter systems over the course of the season).
-Brando
