Go to Post Now why did it take 24 pages for someone to think of that?? It's so obvious it's painful. - Nuttyman54 [more]
  #31   Spotlight this post!
Unread 08-08-2013, 11:31
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
Re: NI Week Athena Announcement and Q&A Panel
Originally Posted by Jon Stratis View Post
As the device runs on CAN, I would assume you can utilize more than one of the devices on the robot at a time. From what I've seen inspecting, a majority of teams don't need more than 4 double solenoids. Since you have to draw the line somewhere (4, 8, 20, whatever), why not keep the whole thing as small as possible while making it all most teams need? The teams that need more will get more by adding more boards.
What Jon said +1.
Also, teams can use single acting Solenoids and reduce the number of outputs needed. As long as they are comfortable with having a default state of their cylinder, that will actuate at the end of the match or loss of comms.
The CTRE device is replacing the current solenoid module that has 8 outputs, but allows for easier (and less weight) expansion of more outputs.
-Clinton-
  #32   Spotlight this post!
Unread 08-08-2013, 11:48
foote stepped in
AKA: E. Foote
FRC #0868
Originally Posted by magnets View Post
A gyro would have trouble if a team decided to mount their control system vertically, or if they didn't put the controller in the center of the robot. Every year we get these accelerometers in the KoP, and I still have no idea what to do with them. We have like 10.
There are 3 axis gyros as well. I used a digital I2C one in my senior design project. The chip (L3GD20) had a footprint of about 4mm x 4mm, wonder if they can fit one on in future revisions?
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
  #33   Spotlight this post!
Unread 08-08-2013, 11:55
Originally Posted by apalrd View Post
--I'm not worried about enough IO, but a few more ADC's would be nice for extra datalogging. Buzz18 uses 5 of 7 and Buzz 17 used 6 of 7, and it's nice to look at other analog signals every now and then. I also wonder if the 5v/3.3v supply is monitored by the ADC separately because we like to look at that for diagnostics, and previously used a jumper in adc7 to do this, which consumes an analog channel.
The specs list 8 ADC and 2 DAC. Presumably, the extra ones are on the Custom Electronics Port. Since the ADCs are 12 bit 0-5v, we get 2 free bits compared to the current cRIO, as long as you don't care about -10 to 10v.
  #34   Spotlight this post!
Unread 08-08-2013, 11:56
AdamHeard's Avatar
Lead Mentor
This is not good. The eight solenoid control really only allows for 4 solenoids, as the double solenoids require two channels to operate. With the relays it will allow for a total of 8 double solenoids. I know that 118 has used more than this in the past, and 236's bump thing used 8 just for their wheels, plus 2 or 3 more on the rest of the bot.
The relay outputs onboard are intended to drive a spike I imagine, if they are keeping with the nomenclature of the sidecar (and the fact that they are three pins confirms this).
Driving pneumatics off a spike is doable, but really doesn't make any sense in this era.
The CAN based pneumatics bumper would presumably allow effectively unlimited for FRC sake.
Also, no way 236 used more than 8 solenoids for that motion. I just don't see enough going on for that.
  #35   Spotlight this post!
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
how does one use livestream. i made an account and went to the link provided but there isn't a video feed, just a few posts with pics of the new controller. it says there are 300+ watching but i can't find it!! please an old guy out :-)
  #36   Spotlight this post!
Unread 08-08-2013, 11:58
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Nothing is streaming yet(well, not until <2 minutes from now)
EDIT: As I typed that, the stream started, albeit with a lost signal message(That went away as I edited this post...)
  #37   Spotlight this post!
wilsonmw04's Avatar
Coach
NM! it starts on its own...
  #38   Spotlight this post!
Unread 08-08-2013, 11:59
AdamHeard's Avatar
Lead Mentor
Anyone know when the video from this morning will be posted?
  #39   Spotlight this post!
Refresh, they just posted the stream.
  #40   Spotlight this post!
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Q&A Starting!
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
  #41   Spotlight this post!
Unread 08-08-2013, 12:13
AKA: Scooby
From the Q&A, there will be an expansion port for your own electronics/more analog inputs.
  #42   Spotlight this post!
Unread 08-08-2013, 12:16
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
  • Deploying over USB will be available.
  • LabVIEW Pro Edition, Java SE, and C++ 11 will be used.
  • Both Ethernet and USB radios are compatible, they are still testing to find which radio will be used.
  • Ethernet cameras (i.e. Axis cameras), USB camera (less expensive), and even commercial cameras (high quality).
  • Targeting low $400s in price, and expecting for it to eventually lower in the future. Expect a more firm answer at the 2014 Championship.
  • The Kinect will be available to interface directly to the RoboRIO, but NI doesn't plan on including native support.
  • Reverse polarity protection +- 12V
  • Library level (not processor level) software simulator.
  • Additional diagnostic tools will be available in the driverstation for teams, and in the FMS for event staff.
  • RoboRIO will have conformal coating.
  • 1 RoboRIO will be available per team at a reduced rate once per year, additional units will be at the academic price.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
  #43   Spotlight this post!
Unread 08-08-2013, 12:17
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Kate won't say whether the roboRIO is even allowed for 2015.
  #44   Spotlight this post!
Unread 08-08-2013, 12:18
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Java SE! Java SE! Java SE!
  #45   Spotlight this post!
Unread 08-08-2013, 12:19
magnets's Avatar
magnets magnets is offline
We will use Java SE, not ME, and we'll be programming in eclipse!
