Go to Post It sounded like a good idea, and then I thought about it. :-/ - Wetzel [more]
Unread 03-02-2003, 18:17
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Need RC Fuse
I was wondering why our rc radio didn't show a signal. Upon closer inspection of the rc, fuse 1-3 are in place but for some reason, there seems to be no fuse 4 (F4). Where can I get more of these? Are they interchangeable with the fuse 4 from last year's rc?
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 03-02-2003, 18:29
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
The fuses are interchangable from old robots but if you never recived one this year I would contact Innovation First and have them send you one.
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
Unread 03-02-2003, 21:46
The "slow-blow, TR-5" fuses are available from Innovation First or Electronics suppliers. I have it on good authority, it says so in the IFI manual.
I bought some from DigiKey in our first First.
Unread 03-02-2003, 22:06
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
I found an old fuse from the 2001 game... same fuse and works just as well
Aux Fuse 3 (Yaw Rate) Josh Hambright Electrical 0 18-02-2003 08:22
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
Blowing 60 Amp fuse archiver 1999 4 23-06-2002 22:07
Fuse Panels punarhero Electrical 5 18-02-2002 10:52
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 12-01-2002 19:51
