Go to Post So when a team leader decides to give all their heart to a team, it is true love that they exhibit towards it. - Anton Abaya [more]
  #76   Spotlight this post!
Unread 08-08-2013, 19:33
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Re: NI Week Athena Announcement and Q&A Panel
FPGA?
The Zynq Chipset is a combined ARM Cortex A9 dual core and FPGA. Pretty cool if you ask me! I posted the links in one of my last posts, but here is the Zynq page: http://www.xilinx.com/products/silic...7000/index.htm
  #77   Spotlight this post!
Unread 08-08-2013, 20:39
pigpenguin's Avatar
pigpenguin pigpenguin is offline
Registered insane
AKA: Ethan Rooke
FRC #1160 (Titanium Robotics)
pigpenguin is an unknown quantity at this point
Confused on servo power, due to lack of jumpers and everything. Is it software defined some how? Or will we need a separate board to run servos?
"Insanity isn't a plea its a way of life and here we are all one card short"
  #78   Spotlight this post!
Unread 08-08-2013, 21:03
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
It's definitely unclear. Specs 6V servo power so I guess it's software controlled.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Last edited by Peter Johnson : 08-08-2013 at 21:05. Reason: Missed the 6V servo voltage spec
  #79   Spotlight this post!
Unread 08-08-2013, 21:14
WPILib Developer
Can anyone identify the connector being used for CAN bus? It almost looks like it only has two pins.. where are the +5V and ground pins?
  #80   Spotlight this post!
Unread 08-08-2013, 21:42
FRC speed controllers don't connect the power pin to anything, odds are that they just routed 6v to the power pin on all of the PWM pins.
The CAN connector looks a lot like the power connector on the 2CAN. Probably just the two wires. As a differential bus CAN shouldn't need the 5V and GND being passed around.
  #81   Spotlight this post!
Unread 08-08-2013, 22:04
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Correct. PWM power pins are 6V, and you get a couple of amps for driving servos.
Correct as well - the CAN topology in this system does not distribute power. Power would be supplied to each device separately.
  #82   Spotlight this post!
Unread 08-08-2013, 22:09
Meshbeard's Avatar
Meshbeard Meshbeard is offline
Previously of 422
AKA: Jonas
FRC #0190 (190)
Meshbeard is a name known to allMeshbeard is a name known to allMeshbeard is a name known to allMeshbeard is a name known to allMeshbeard is a name known to allMeshbeard is a name known to all
I'd assume that those two connectors are for the CAN-high and CAN-low wires. Power is probably separate since all the power systems on an FRC robot are separate from the controls.
What will likely happen is all of CTRE's new CAN stuff will have those two CAN ports separate from the regular old 12v power inputs on all the other components.
  #83   Spotlight this post!
Unread 08-08-2013, 22:26
donkehote's Avatar
donkehote donkehote is offline
Design/Manufacture/Strategy Mentor
AKA: Kevin
FRC #5031
donkehote is just really nicedonkehote is just really nicedonkehote is just really nicedonkehote is just really nice
i wish they had gotten a better toaster to record the webcast. I sincerely hope that the roborio can process better video quality than the webcast.
Joking aside, it looks great! I really like the smaller footprint, the lighter weight, and the canbus support. Do i see an optical port at the top next to the USB? would that be for faster camera response, or is it some other connector for something.
  #84   Spotlight this post!
Unread 08-08-2013, 22:49
Are you talking about the USB B connector? (To the left of the 2 USB A connectors)
  #85   Spotlight this post!
Unread 08-08-2013, 22:56
donkehote's Avatar
AKA: Kevin
FRC #5031
Oh, its a USB B, that's what it is. i was thinking it looked like the optical audio port and i was wondering what it would be for.
  #86   Spotlight this post!
Unread 08-08-2013, 23:33
I believe Greg mentioned that the USB B port could be used to drop programs into the roboRIO.
  #87   Spotlight this post!
Unread 08-08-2013, 23:52
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Originally Posted by Gregor View Post
  • C++ 11 will be used.
I'm pretty happy about that detail.
  #88   Spotlight this post!
Unread 09-08-2013, 01:02
WPILib Developer
For robustness some systems pass around the control power. In these systems, the CAN bus control logic on each component is powered from the CAN bus power lines instead of the mains supply, ensuring the component is always reachable even if the mains supply to that component is lost (with optoisolation between the CAN control logic and the rest of the circuitry). This could be useful even in the FRC world: for example, tripping a breaker would not cause that CAN bus component (e.g. motor controller) to drop off the bus (so you could still pull status, and it could report it doesn't have mains power etc).
There is a serious problem with the current CAN layer where timeouts to Jaguars could swamp other parts of the system due to error spamming. As timeouts can be caused for multiple reasons (bad termination, disconnected cable, etc), regardless of the power distribution approach, my hope is that the software layer will be updated to avoid this issue.
  #89   Spotlight this post!
Unread 09-08-2013, 02:35
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Note the new PDB is CAN enabled so it can report a tripped breaker as well as the current flowing through each breaker. So you will be able to tell if something on the BUS isn't responding due to a tripped/cycling breaker.
  #90   Spotlight this post!
Unread 09-08-2013, 08:48
DonRotolo's Avatar
Back to humble
FRC #0832
EDIT: There is a hardware connection within the Jags to prevent this (see posts following)
The current Jaguar CAN has us daisy-chaining network nodes, so if one drops the network, everything beyond it becomes unreachable.
In the automotive world, (most) CAN Buses have a star architecture, everyone hears everything, always.
