Go to Post I would say that you are not an engineer until you've both obtained the aforementioned peice of paper AND done something with your tumescent engineers forebrain. - phrontist [more]
Unread 20-06-2013, 22:37
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Looking for contributors for an open-source FRC library
Hey off-season browsers,
The last year, I've been on a journey to make a base API that can make programming easier for teams. The goal has be a moving target so far, but I now have a pretty clear vision and project set up.
What I'm looking for
  • People who know Java
  • People with experience with documentation
  • People who have programmed plugins for popular IDEs (Eclipse, Netbeans, IntelliJ)
  • People who who C++
If you fit under any of those categories, please tell me about it! I'm not looking for any huge time commitments, just for more people with different skill-sets than me.
Project here
*Code is here - https://github.com/Summer-of-FIRST/atalibj
All opinions are my own.
Unread 21-06-2013, 15:47
ohrly?'s Avatar
ohrly? ohrly? is offline
Griffin Alum
AKA: Colin Poler
FRC #1884 (The Griffins)
ohrly? is an unknown quantity at this point
Re: Looking for contributors for an open-source FRC library
Love it. I built an eerily similar library in 2012, so I'll submit a pull request once I change my code to match yours.
Two questions: will this be built on top of WPILibJ and replace it later, or is it designed to replace WPILibJ from the start? Is there any C++ component, or is this solely a java library? (I'm fine with either)
Also, it may be wise to contain the platform specific (low level FPGA commands / WPILibJ calls) to a small area of the code, so that ATALibJ can be ported to the 2015 platform more easily.
One last thing: it might be better to put everything under org.first, because http://first.edu/ isn't related to FRC
Unread 21-06-2013, 18:25
AKA: Joel Gallant
Thanks for the interest.
It's currently built on top of wpilibj. I plan to eventually (hopefully) make it self-dependent.
No C++ equivalent yet. I was hoping somebody could port it for me, since I'm not familiar with C++ yet.
I agree. Hopefully I can make the implementation hidden enough that it will easily be replaced.
Unread 21-06-2013, 23:42
AKA: Joel Gallant
If there is anyone with experience with technical documentation, let me know.
Unread 31-07-2013, 13:57
Curandil's Avatar
Curandil Curandil is offline
Controls team mentor (Programming)
FRC #4279 (Robo Revolution)
Curandil is an unknown quantity at this point
I'm currently building 100% Java based Point-Of-Sale systems for a living. I have been doing Java and web based development since about 1996.
Not my most favorite task but I have written Technical documents. The target audience for the technical documents have always been other developers usually the ones that have to make use of our subsystems.
I have not done a plugin yet in any of the IDEs but I have used and worked with Eclipse and IntelliJ. I've used Netbeans but only to bootstrap the FRC code so I could port it over into an Eclipse project. I'm also fluent in Emacs and Vi.
>People who who C++
I have over 10 years experience developing C/C++ applications in a large scale Telecommunications environment as well as Scientific applications.
I'd be willing to lend support wherever you might need it. I might even be able to get some of our Programming team to help out as well. Feel free to private message me.
Good luck,
Curandil
Team 4279 - Robo Revolution
Mentor - Programming Group
Unread 08-08-2013, 19:40
tragic tragic is offline
Programming Mentor
FRC #4633 (Bobcats)
tragic is an unknown quantity at this point
Is there still room for a C++ coder? I would be willing to commit some of my time to helping out as I think replacing WPI.lib with something more streamlined could be a big improvement for First. I also think I may have some idea's that could help to improve or expand the project.
Unread 08-08-2013, 20:03
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
I can help out with the C++ effort if there's still a need.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 09-08-2013, 00:31
AKA: Joel Gallant
I'd love if someone could pickup a C++ effort for porting. I'm not familiar with C++ enough to do it.
https://github.com/Team4334/atalibj
Code is all here. You could fork it and slowly replace files or just make your own repo with C++ versions. Once it has a decent amount of stuff, I can merge it into a new branch.
Unread 09-08-2013, 00:48
Programming Mentor
FRC #4633 (Bobcats)
Ill look into learning some of the Java keywords to read the source(its similar to C/C++ so shouldn't take long) and I will begin recreating the files in C++.
Unread 09-08-2013, 14:35
AKA: Joel Gallant
Awesome. Let me know if you need help.
Unread 10-08-2013, 15:37
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
Having just ported our 2013 code from C++ to Java, I am familiar with both languages. If you would like some additional help with the C++ port of ATALibJ, I may be able to contribute.
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
Unread 12-08-2013, 17:45
AKA: Joel Gallant
Absolutely. Can you start by porting some code and putting it in a separate repository?
Unread 13-08-2013, 13:27
I forked the project on GitHub, and started work on a C++ port here: https://github.com/DomenicP/atalibj/tree/cpp. Unfortunately I don't have access to WindRiver Workbench at the moment, so I'm unable to compile the code to make sure it's working. Might be a couple of weeks before I can obtain the install disks again, since my team doesn't meet in August.
Unread 14-08-2013, 19:14
Update: After messing around with it for a while, I was able to get the C++11 toolchain from FIRST Forge working on an Arch Linux VM. I'll be working with this until I can reinstall WindRiver; as far as I know the code should behave the same in both environments. I also started a separate repository found here: http://github.com/DomenicP/atalibcpp.
Unread 15-08-2013, 00:35
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
I'm also (more-than) familiar with both Java and C++ and would love to jump in on this!
For the documentation, I highly recommend following JavaDoc syntax(or Doxygen for C++). This would make 90% of the documentation basically write itself.
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
