Go to Post I'd rather have a target on my back than be invisible to the competition. - Chris is me [more]
Unread 09-08-2013, 00:14
yash101 yash101 is offline
AKA: null
CIM motors on driver station
I have an idea for a 'smart' driver station that can make batterywork and worrying about if the driver station has enough power much easier. I was thinking that it would be feasible to use a car battery to power the entire cart. However, when I was calculating the weight of the cart plus the cargo, it seems that at least two people tugging at their full potential would be required to push the weight. Could it be possible for me to place CIM motors with victors, connected to my controller to help reduce the amount that the human would need to push. I was thinking that touch sensors should b placed on the handlebars to trigger the motors when a certain amount of force if applied. If the driver loses control and lets go of the cart, the cart should automatically go into brake mode (I think that will work on victors). Note, the project homepage is located on my personal homepage, located at:
http://devstuff.no-ip.info
Unread 09-08-2013, 00:52
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: CIM motors on driver station
Many teams have made powered carts which do not rely on humans to push at all, but instead are driven and steered like a robot, using built in controls or a tethered control unit.
Be aware though that queuers are generally not fans of this type of cart, as they are hard for them to move around if they have to, since they will not be familiar with the control setup. Generally its advisable to give the cart the capability to shift into "neutral," so that it can be manually pushed as well as need be.
Unread 09-08-2013, 01:09
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
I'm a little confused by your posts. Are you trying to build something that combines the driver station and the cart? Would the cart be in the driver station during matches? I'm not sure what the FTAs at your events are going to say about something like that. I also think it might be against the rules but that's probably something for next year's Q&A.
Unread 09-08-2013, 02:47
ablatner ablatner is offline
AKA: Andrew Blatner
FRC #0100 (The Wildhats)
ablatner is on a distinguished road
Let's think about this. Your goal is to make sure your laptop and peripherals have enough power and won't go out during a match (happened to us a couple times the past few years...). First off, get a new laptop battery, or maybe even a cheap new laptop with good battery life. Second, you can get a DC-AC power inverter. It converts a robot battery's 12VDC to 120VAC like a wall outlet. The battery plugs into one end, and the laptop charger the other. Cheaper, simpler, more reliable.
Of course, if want to do your powered cart because it's a fun project, then by all means go for it. Just keep this in mind too.
2009-2013: Student, Team 100
2013-????: ?
Unread 09-08-2013, 07:34
As I responded in your other post, safety is a great concern. Most venues get very tight in the queue and having a powered cart is really not the best thing in those cases.
Unread 10-08-2013, 12:29
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Talk to someone from team 1806. They had a moving cart at champs, but I'm not sure how they did it.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 10-08-2013, 23:19
Stark4Prez23's Avatar
Stark4Prez23 Stark4Prez23 is offline
AKA: Ashrita Raghuram
FRC #2022 (Titan Robotics)
Stark4Prez23 will become famous soon enoughStark4Prez23 will become famous soon enough
Theirs was donated to them. It was just a cargo forklift kinda thing that they adjusted for placing a robot on. I agree with the other posts though, because it could become a safety hazard. Good luck!
Ashrita Raghuram
IMSA Titan Robotics
Oswego Gear it Forward #2338
Rookie Year:2013
FIRST Wisconsin Regional Winners: 111, 1732
FIRST Midwest Regional Semi-Finalists: 111, 1625
FIRST Championships
7th Seed Alliance Captain Galileo Division
FIRST Central Illinois Regional Semifinalist
Unread 12-08-2013, 11:14
evanperryg's Avatar
AKA: Evan Grove
I would say try a kitbot with a really low-speed gearing. That would make it easy to control and powerful enough to carry the robot and everything else. What, exactly, is the advantage of a powered cart? I understand it's cool to show off, but it seems like a lot of resources for something with minimal benefit.
2013
2015
