Go to Post It's not all about the offensive "powerhouses", strategy is key. - smurfgirl [more]
Unread 08-08-2013, 15:51
sarah_storer's Avatar
sarah_storer sarah_storer is offline
Georgia Tech RoboJackets Outreach
AKA: Sarah Storer
FRC #5332 (Toaster Tech)
sarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to behold
Axis Camera Issues
When I plug my camera into the power cord that we have connected to the bot the camera does not come on. I used a voltmeter to check and make sure the PDB was giving off 5 volts...it was...I checked the end of the camera cord to see if it was delivering 5 volts....it was.
The camera is not wired backwards so I'm pretty sure we didn't fry it.
This is exactly what happened to a camera we had last year, it just wouldn't power it on. We assumed it was the camera but really had no clue. We bought another one and it worked for a while but now when I try to get it to work it won't.
Any solutions?
Thank you!
TEAM 3753 BULAH BOTS ALUMNI
2012-2015: Code, pneumatics, and electrical for BULAH BOTS Team 3753
2013: Bayou Regional 1st seed alliance captain and regional winners (With 118 and 4589)
2014, 2015: Bayou Regional semi-finalist
2016-?: Mentor for TOASTER TECH Team 5332
2016: Columbus District 3rd seed alliance captain, semi-finalist; Kennesaw District 3rd seed alliance 1st pick, semi-finalist; Peachtree District State Championship 4th seed alliance captain, quarter-finalist, Industrial Design Award, World Championship qualification
Unread 08-08-2013, 18:45
Aaron.Graeve Aaron.Graeve is offline
FRC #1477 (Texas Torque)
Aaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to all
Re: Axis Camera Issues
When you try to power on the camera, do lights appear around the lens and, if so, what color are they? I seriously doubt you fried it, but it is possible.
Alamo, Bayou, and Lone Star Regional FTAA
2015:
Dallas, Alamo, Bayou, and Lone Star Regional FTAA
2014:
Alamo, Dallas, and Lone Star Regional FTAA
Alamo Regional Robot Inspector
2013:
Einstein Champion and 2013 World Champion (Thanks 1241 & 610), Galileo Division Champion, Razorback Regional Winner, Alamo Regional Semifinalist, Bayou Regional Semifinalist, Lone Star Regional Quarterfinialist
2012:
Curie Division Semifinalist, Lone Star Regional Finalist, Bayou Regional Winner, Alamo Regional Winner
Unread 08-08-2013, 18:59
There are status lights on the back of the camera too that can help tell what's going on.
Is the polarity of the 5v barrel connector correct (center positive)?
Unread 09-08-2013, 13:13
AKA: Sarah Storer
There are absolutely no lights that come on when I plug the power cord into it. I checked the polarity too and it was correct.
Unread 09-08-2013, 13:42
Sounds like the camera is burned then.
If you still have the wall transformer that came with the camera (and didn't cut it off to use just the connector on the robot) you can try that as a last resort test.
Unread 09-08-2013, 13:48
I agree with the post above. It sounds like it is burned out. That is unfortunate. It could be worse though; you could have fried your cRIO.
2015:
2014:
2013:
2012:
Unread 10-08-2013, 12:39
Luckily cRIOs are considerably harder to fry. They sizzle for quite some time before that happens.
Also, you may want to use a multimeter to verify that the voltage being provided to the camera is what you think it is -- especially before connecting another.
Greg McKaskle
Unread 15-08-2013, 10:54
AKA: Sarah Storer
Alright thanks guys! :/
This is pretty unfortunate since this is the SECOND camera this has happened to....eh...like you said, it could be worse
