Go to Post Honestly I'm looking forward to just seeing all my friends again, that's what FIRST is really about to me. - Barry Bonzack [more]
Unread 10-08-2013, 07:44
jameschin jameschin is offline
FTC #0310 (Fission)
jameschin is an unknown quantity at this point
Tank Drive Without a Microcontroller
If you didn't want to use a microcontroller, is it possible to make a tank drive such that it was directly wired to potentiometers?
Unread 10-08-2013, 08:28
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: Tank Drive Without a Microcontroller
It certainly seems feasible, assuming you can get a linear response out of the pots. The one difficulty I'd see is controlling it remotely, but even that might be doable with some model airplane electronics.
I code stuff.
Unread 10-08-2013, 08:54
It's not clear what you are asking. What are you proposing to directly wire the potentiometers to?
In principle you could wire a pot directly to a DC brushed motor (like a CIM), but in practice it would have to be a very heavy duty pot, and it would waste a lot of battery power (and get hot).
Wiring a pot directly to a Talon or Jag or Vic would not work. These devices require a PWM input signal, not a DC voltage..
Unread 10-08-2013, 08:57
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Sure just use a microprocessor without integrated peripherals
Need to watch your terminology here.
I wonder if digital logic is outside your request or just integrated computing.
You can build analog speed controls.
They can be adjusted with potentiometers.
They can recieve from various radio modulations.
I have done it before for non-FIRST application.
An analog speed control can still pulse the motor like the FIRST speed controls.
So an analog speed control need not be resistive or linear to the motor.
However analog speed controls suffer from temperature and noise limits (drift).
Thermistors help with temperature but only to a point.
It is entirely possible to fly an actual plane with analog electronics.
If integrated circuits are still allowed within your scope it is even easier and smaller.
Then you have tiny operational amplifiers.
If digital logic is allowed take a good look at the 555 timer.
I won a contest in highschool driving hobby servos without their board using 558 IC.
I only implemented a single joystick then but I could have made 2.
You can drive a PWM input with merely simple timers like the 555 using PWM.
It is possible you just need to tinker a bit.
See Analog Systems:
http://en.m.wikipedia.org/wiki/Fly-by-wire
Unread 10-08-2013, 09:39
magnets's Avatar
magnets magnets is offline
If you are planning to control motors like CIMs, you will need to use a speed controller like a victor or a jaguar. If you want to generate the pwm signal without using a microcontroller, you will need a 555 timer. Team 358 has a schematic for a circuit that can control a victor here. You could use this to control your victors.
Unread 10-08-2013, 11:14
techhelpbb's Avatar
All the FIRST approved motor controllers have microcontrollers in them.
The circuit to drive a DC brush motor like the CIMs with pulsed power is an analog/digital chopper.
Circuits without microcontrollers existed for decades.
Motor control chopper (generic term) come in time (like PWM) or current/voltage control.
Current/voltage control choppers have a wider range of speeds with good torque.
Complexity and wasted energy tends to increase for current/voltage choppers.
It is unclear exactly what is being looked for in this topic.
Like Ether wrote if you have a high power resistor/potentiometer/rheostat you can make this work.
However a chopper circuit is better with larger motors.
The pulsing dramatically impacts the waste heat.
You can make a relatively small speed control for a CIM sized motor without a microcontroller.
I did it for wheelchairs.
Just consider that all features require more parts.
Unread 10-08-2013, 22:06
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
1. As has been said, you can't control a Jaguar, Victor, or Talon directly with a potentiometer.
2. There are other COTS speed controllers (not FIRST-legal) that accept analog input. I've used the Sabertooth series in personal projects before and have been happy with them. Some models from this series accept analog input, and there are models that can switch up to 60A per motor channel. You can get them on Trossen Robotics or Robot Shop
3. If you want a remote-controlled system that requires no programming, that's entirely possible. The PWM signal that Jaguars, Victors, and Talons accept is a standard signal type outputted by many (if not most) hobby RC systems.
4. If you're looking to easily test your speed controllers without the need for a microcontroller, AndyMark has a product for that, or you can build your own version, as has been said.
FRC 766, 2015-, Mentor
Last edited by RyanCahoon : 10-08-2013 at 22:08. Reason: Added links for Sabertooth controllers, fixed AndyMark link
Unread 11-08-2013, 12:53
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Yes a little unclear, but a servo tester may fit the bill?
http://www.andymark.com/product-p/am-2503.htm
We have a few that we picked up at a hobby shop for less than $10 each, but they don't seem to run a jag or a victor to full speed, but perfectly fine for testing systems. The AM one started last year, and may be calibrated to the motor controllers, as opposed to the hobby servos? Or maybe you get what you pay for?
The sooner we get behind schedule, the more time we have to catch up.
Unread 11-08-2013, 13:22
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Did you make sure to re-calibrate the Jag (I haven't used a victor before so I am unsure as to what is necessary for them). If you go on the vex website they provide documentation on how to re-calibrate the Jag for different pulse width ranges. We had the same issue where the Jag would only put out 50% power when we used a servo controller on a test board we built. Once we re-calibrated the Jag with that servo controller it worked perfectly. Just make sure that you re-calibrate the Jag once it goes back on the robot.
Unread 11-08-2013, 14:55
An old junker laptop makes an ideal PWM generator for testing. All you need is some software and a cheap diode and resistor. You can adjust the PWM period and the max pulse width.
http://www.chiefdelphi.com/media/papers/2702
Unread 12-08-2013, 06:07
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
We did try to calibrate the victors, and it improved, but still not ideal. The servo tester we have would go almost full speed in one direction, and about 1/2 speed in the other direction. We were using this to prototype the shooter last year. I ended up using an arduino, the ardunio servo library, a little code to convert an analog pot to servo pwm output. It worked fine for both Jags and Victors out of the box. (not sure what the difference in the inputs are, I know you declare the controller type in labview, so would suspect there is some difference, but did not notice it on the arduino.)
Unread 12-08-2013, 08:34
arizonafoxx's Avatar
arizonafoxx arizonafoxx is offline
FRC #4395 (T-Rex)
arizonafoxx is an unknown quantity at this point
Depending on the size of the motors you want to use and how you reduce the speed you could use spike relays, which would not require a micro to control them. This of course would cause the motors to either be full speed in fwd/rev or stopped, but if your robots full speed was something manageable like maybe 4ft per second that is totally plausible. All you would need is 5 volt inputs to the spikes which could easily come from buttons or other non-micro related circuitry. I have built a few robots like this. Tank drive is achieved but speed control is not desired.
Unread 12-08-2013, 17:56
The Victor PWM pulse width is 1-2ms. The Jaguar PWM pulse width is .67-2.33ms.
Unread 12-08-2013, 18:10
AdamHeard's Avatar
Lead Mentor
A hobby RC radio is ideal here, it even has multiple channels for other systems.
V-tail mixing is the same as arcade drive.
AndyMark now stocks a popular and affordable chinese model.
Unread 13-08-2013, 09:54
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
AndyMark has something called the 'cheap and dirty' control system for under $60. It seems to be exactly what you need if you are willing to spend that amount of money. http://www.andymark.com/product-p/am-2520.htm
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
