Go to Post I don't know how much of a safety factor chain manufacturers build into these ratings. I've got empirical evidence to demonstrate that it's not 5, however. - Tristan Lall [more]
Unread 11-08-2013, 16:26
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Frisbee shooter surface?
I have been wondering (because I have not seen much on the subject) on what people have been using as the "floor" of their shooter, aka "what the frisbee slides across."
I have seen plywood, metal, and some plastic, but after testing did anyone find that one material worked better than another?
Thank you!
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 11-08-2013, 16:44
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: Frisbee shooter surface?
We've had frisbees slide on a lot of materials, both in prototyping and on the robot. We've had Frisbees sliding on aluminuim, powdercoated and unpowdercoated, polycarb, ABS and wood.
Probably the worst was the unfinished plywood we used in prototypes, but anything other than that worked fine. Of the materials we tested, the powdercoated aluminium in our final shooter was probably the "best" although ABS was pretty good and I'm sure HDPE would be even "better." The reality is that frisbees slide really well on a lot of materials. They're relatively hard plastic with not much contact area, so as long as the shooter surface isn't bumpy or sticky, they should slide pretty well.
Aluminuim (powdercoated if you can) or ABS are probably your best bets. I don't think there's any need to spring for teflon coated aluminium or HDPE or anything like that. You should be fine with a lot of materials, just be sure you or someone else has tested it before using it.
-Plutarch
Unread 11-08-2013, 16:52
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
We used smooth aluminum that was the inside of a c-channel (well, two c-channels), I don't remember which type.
We didn't do any tests, but I see no reason not to go with the smoothest material you can find, as long as you know it won't break (which I doubt will happen with any but the flimsiest of materials).
Since the disc touches it all the way through its lip (or at least on the sides, but it'll almost certainly be both sides), so the friction between the disc and the "floor" doesn't change the spin, only slows the disc down, so you want as little of it as possible.
Team FRC#2212 The Spikes, 2011-...
Builld leader 2013
Drive coach 2012-2013
Mentor 2015-...
Unread 11-08-2013, 17:02
Andrew Lawrence
Posts: n/a
During the competition season, our frisbees slid across polished steel .5x.5x.0625 tubing beautifully. No catches, very little friction, and perfect support. While I don't plan on using steel for an entire robot anytime soon, if we had another disc game, I'd definitely consider using polished welded steel tubing as a floor again.
Unread 11-08-2013, 18:09
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
We had a pretty accurate full court shooter that didn't have anything for the frisbee to slide on. We had a V shaped curved rail made out of HDPE that the frisbee rested in. You must make the V in such a way that the frisbee does not wobble when being fired though.
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Originally, we had the concern that we needed a smooth surface for our frisbees to slide on (despite a wooden prototype that could easily shoot the length of the field). We decided to put a piece of abs on top of our wooden shooter arm so that the frisbees would slide on that. However, when we realized we were overweight (which will happen if you build a wooden robot, even with a <30in tall robot and the smaller frame perimeter), we decided to remove the abs, and let the frisbee slide on painted wood. It only ended up shooting half as far (although there is a good chance that this happened because of another cause), but we aren't a full court shooter so distance didn't matter much. Precision is what matters more. At the Boston Regional on Friday, we made 27/27 shots in autonomous. On Saturday, our precision declined so that we would often only make about 2/3 shots in autonomous. At Beantown Blitz, our precision was down to about 1.5/3 shots. Could this deterioration be because we used wood? Maybe, I will let you be the judge of that.
Unread 11-08-2013, 18:17
FRC #1836 (MilkenKnights)
Polycarb worked well for us, though we didn't try other materials. anything smooth should work quite well
Unread 11-08-2013, 18:26
GarroH GarroH is offline
AKA: Garrison Hefter
no team (None)
GarroH will become famous soon enough
We used a shooter made completely from HDPE. This includes the deck (or floor), the rails to provide the semicircular shape, the hopper to hold the disks (that part also included a pickle bucked), and the wheel. This worked great as far as the sliding, shooting and manufacturing goes.
The main problem we ran into was the warping. Even with the aluminum angle support we added under the deck, it still warped throughout the season. This was partly our fault for not adding any of this support until we saw the problem midway though the season.
FRC 2468 2011-2014
FRC 190 2015
Unread 11-08-2013, 18:29
Originally Posted by GarroH View Post
We used a shooter made completely from HDPE. This includes the deck (or floor), the rails to provide the semicircular shape...
Did you apply friction tape to the rails to promote spinning?
Unread 11-08-2013, 18:40
no team (None)
We thought about friction tape, but in the end we made the shooter rails a little bit bigger and farther away than we knew we would need to add thin strips of Lexan as spacers. On top of those we put a black foam strip we got at Home Depot.
Very similar, if not the same to this:
http://www.homedepot.com/p/Frost-Kin...4#.UggSy9I3vSg
FRC 2468 2011-2014
FRC 190 2015
Unread 11-08-2013, 19:23
Wolffy Wolffy is offline
AKA: Steven Wolff
FRC #0250 (The Dynamos)
Team Role: Human Player
Wolffy is an unknown quantity at this point
My team used a simple peace of polycarbonate. We found ouy that the deck surface did not matter as much as the side rail surface. We applied a thin strip of sand paper and saw drastic results of faster shooting speeds as well as an exponential increase in range.
Unread 11-08-2013, 19:35
T^2 T^2 is offline
FRC #5499
Teflon tape.
McMaster 6305A18
Unread 11-08-2013, 20:30
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
We used carbon-fiber on a plywood core. The Frisbee contacted the gel-coat surface.
We applied a strip of rubber to the outer arc for friction.
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 12-08-2013, 01:38
donkehote's Avatar
donkehote donkehote is offline
Design/Manufacture/Strategy Mentor
AKA: Kevin
FRC #5031
donkehote is just really nicedonkehote is just really nicedonkehote is just really nicedonkehote is just really nice
We used HDPE strips for the bottom of our shooter. as noted above, we noticed more improvement from changes to the backing over changes to the deck.
Our backing material is of choice is vertically ridged rubber conveyor belting material.
You can see the 7 HDPE curved sections, and the green rubber backing inside the shooter.
The 7 segments are all cut from one 3/8 thick piece of HDPE we got from a local plastics supplier. The segments nest inside each other. It was reasonably cheap. we could adjust the height using polycarb spacers, moving the slides up/down to suit.
Also, we turtle waxed the other surfaces the frisbee was in contact with. the hopper, intake polycarb and the feeder slot slide were all liberally waxed up after every few matches or so. Ask code orange how much of a difference it makes. We introduced them to it at IRI.
Unread 12-08-2013, 09:42
HumblePie's Avatar
HumblePie HumblePie is offline
AKA: Mista Doug
FRC #3489 (Category 5)
HumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really nice
Our shooter surface was a piece of 1/8" thick plastic material called Starboard. It's designed for marine applications and has a nice grainy surface that reduced the surface area in contact with the disk. In our testing, disks slid across the Starboard much more easily than polycarbonate. For rigidity (at a low weight penalty) we laminated the Starboard to a 1/4" piece of Coroplast and had the sandwich waterjet cut by a sponsor.
FRC Team 3489 "Category 5"
