Go to Post Now its up to us to show that what we shout from the high places is also true down on the street. - KenWittlief [more]
Unread 08-12-2013, 10:21 AM
Professional Stat Padder
Re: Frisbee shooter surface?
We just had some HDPE on our floor surface. But we also weren't built to shoot more than a short distance. Our prototype had a wooden surface for the floor, and it shot ever further than our competition bot, but that's more likely due to the additional compression on the prototype.
I think the wheel surface and the surface of the opposite edge it's contacting are far more important in determining accuracy and distance.
If you were to follow any of these people's advice, though, I'd recommend 2468's. Have you seen their shooter? It's deadly accurate from absolutely everywhere on the field. Their's has to be the most consistent shooter I've seen in FRC this year. (Even more consistent than 67, I'd say).
(2015-Present)
Unread 08-12-2013, 10:49 AM
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
The base of the shooter was lexan. There was some roughtop tread on the opposite side from the shooter wheels. We used Pledge (it's a spray) that made the surface very slippery.
Unread 08-12-2013, 11:18 AM
Chris is me's Avatar
AKA: Pinecone
We initially used powdercoated aluminium on both sides of the frisbee, and it worked fine. Later we constrained the frisbee better using two HDPE blocks / strips on the 'top' and powdercoated aluminium on the bottom. If we did it again, we would probably have a pair of HDPE strips on both the top and the bottom. The important thing is to constrain the frisbee so that it cannot flex or tilt significantly.
Unread 08-12-2013, 12:17 PM
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Our setup is similar to 1310's, with a few minor differences. The bottom of our shooter path is entirely HDPE instead of having strips. The back of the arc is also made of layered HDPE - so it's slippery instead of grippy.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 08-12-2013, 01:57 PM
themitchshow themitchshow is offline
I do stuff and things
AKA: Mitchell Petrimoulx
FRC #0027 (Team RUSH)
themitchshow is an unknown quantity at this point
We ended up using Glasliner FRP, better know as the regolith used in 2009. We added a car wax spray to it once or twice a tournament and found it worked quite well.
Mitchell Petrimoulx
Team RUSH Robotics
Unread 08-12-2013, 02:50 PM
spydan's Avatar
spydan spydan is offline
Dan
FRC #0708 (Hatters Robotics)
Team Role: Marketing
spydan is on a distinguished road
Team 708 used 1/2 inch polycarbonate, see the attached photos. Sorry for quality, it is what we had on our website
www.team708.org
FLL Student: Food Factor, Senior Solutions
FRC Student: Ultimate Ascent, Aerial Assist, Recycle Rush, FIRST Stronghold
Volunteer: Ultimate Ascent, Aerial Assist, Nature's Fury (FLL), Recycle Rush, World Class (FLL), Trash Trek (FLL), FIRST Stronghold
My posts do not necessarily reflect the views & opinions of affiliated teams.
Unread 08-12-2013, 10:08 PM
GarroH GarroH is offline
AKA: Garrison Hefter
no team (None)
GarroH will become famous soon enough
Wow, thank you so much for the praise we really "appreciate" it. But my best advise would be to make one shooter multiple times with many of the different materials listed (there are some great shooting teams giving their advise on this thread).
And our machine was built mostly for long distance. Just something to keep in mind when comparing materials and shooters
FRC 2468 2011-2014
FRC 190 2015
Unread 08-12-2013, 10:43 PM
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Originally Posted by GarroH View Post
We thought about friction tape, but in the end we made the shooter rails a little bit bigger and farther away than we knew we would need to add thin strips of Lexan as spacers. On top of those we put a black foam strip we got at Home Depot.
Very similar, if not the same to this:
http://www.homedepot.com/p/Frost-Kin...4#.UggSy9I3vSg
Would you mind sharing a photo of your shooter and how this foam was implemented? (I am having a tough time visualizing it)
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 08-12-2013, 10:52 PM
no team (None)
This is the best picture I could find
https://www.facebook.com/photo.php?f...type=3&theater
You can see the black foam on the inside of the shooter rails at the end of the arc. That runs all the way around the circle until the bucket starts. The shooter rails are also beveled into a sort of "7" shape to keep the frisbees down.
I wish I had the cad or a better picture.
http://www.chiefdelphi.com/media/photos/38565
This pic might help with the rail visualization.
Hope this helps!
Garrison
FRC 2468 2011-2014
FRC 190 2015
Unread 08-12-2013, 11:04 PM
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
We used a cutting board for ours, bought at Walmart. It's developed some notches in it from where frisbees ground on the board when we shot.
2013 North Star Regional Industrial Design Award
2011-2013: FRC #3633 Catalyst
2014-20XX: FRC #3633 College Mentor
RPI Class of '17 / Materials Engineering
Unread 08-13-2013, 12:00 AM
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
We used aluminum. It was the only water jetted thing on our bot, actually.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
