Go to Post Success is making a difference. - SlamminSammy [more]
Unread 11-08-2013, 15:30
K519_1325's Avatar
K519_1325 K519_1325 is offline
AKA: Karan Guglani
FRC #1325 (Inverse Paradox)
K519_1325 is an unknown quantity at this point
Drive Victors not Responding in Autonomous
Drive victors are not responding in autonomous. They work for about half a second and then they disable. The drive victors are fine in teleopertated though. It is only the drive victors not responding in auton. (all other ones are fine) We are using labview.
http://www.team1325.com
Unread 11-08-2013, 16:47
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
Re: Drive Victors not Responding in Autonomous
Can you post your code so that we can take a look at it?
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 11-08-2013, 16:56
Originally Posted by K519_1325 View Post
then they disable
Could you be specific what you mean by "disable" in this context?
What is the Vic's LED doing? What does your DS say the PWM signal to the Vic is set to?
Unread 12-08-2013, 12:20
It sounds like you might be tripping the motor safety. Seeing your code would help confirm whether you are updating the motors often enough to avoid tripping the motor safety.
Unread 12-08-2013, 18:22
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Has your autonomous worked in the past?
I ask because coding autonomous in LabVIEW is not like teleoperated. Teleoperated is encapsulated in a loop external to the VI so that the code is repeated over and over.
Autonomous is not encapsulated in a loop. So if you want it to loop, you have to add your own with your code inside of it. Without that loop, your code will execute once then stop.
That's my first 'guess' at what your trouble might be. Any chance you can post your code?
Unread 13-08-2013, 09:50
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
I would first suggest unplugging all the PWMs and putting them back in. Just do it, even if it doesn't make any sense, the connectors on victors are like black magic. A few questions:
1. When you say 'disabling,' what do you mean? What does the signal light show?
2. What version of the Victor are you using? We had similar troubles with the 884.
3. Have you made any recent changes anywhere in code?
4. Do you have one loop running at the same time as another, and the other is taking priority?
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
