Go to Post I'm gonna laugh when the GDC numbers the first official game hint #3. - Racer26 [more]
Unread 13-08-2013, 16:42
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Defensive wedge done differently
Recently my team has been discussing ideas of what kind of drivetrain we might want to use next season. One discussion points that has often come up is traction. Wheels such as omni and mechanum provide great maneuverability but lack traction and usually void you of most defensive capabilites despite the setup of the rest of your drivetrain. Assuming you havn't built a wheel switching mechanic (that I find would likely take up a lot of space, weight, and time), it's difficult to be both very pushy and agile.
Tell me this: do you think there is any practicality behind a deployable wedge that would act as a traction device and a means of redirecting the force of an opposing robot? The concept would be similar to putting your foot behind you when pushing on something. In theory it could provide a simpler way of calling upon defensive capabilities while still maintaining a very agile robot.
Also, has anyone ever done anything like this before?
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 13-08-2013, 16:55
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Defensive wedge done differently
Do you mean a wedge that lifts other robots? They used to be allowed but the current rule set, normally makes them illegal.
If you mean something that brakes you into the ground when pushed a certain direction, then yes teams have used this before. In fact we helped a rookie team at Razorback this year that had trouble turning with the basic kit bot. We had them take off their back two wheels and add rough top traction to the frame where they used to be. All their weight was in the front of their robot so they could drive normally but if you tried to push them backwards the traction would engage and make them much harder to move. For a two CIM robot, it worked out very well and they played solid defense the rest of the tournament.
Unread 13-08-2013, 16:59
AKA: Spencer Lanman
No, I don't mean to lift other robots, but your example is the concept I'm looking into.
[Edit] Did this modification make it easier to push other robots, or solely prevent other robots from pushing them, at the least?
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 13-08-2013, 17:22
Kpchem Kpchem is offline
FTA, CSA, and all things technical
AKA: Kevin Emery
Kpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to behold
One thing you need to be mindful of when creating this mechanism is that, in years past, there have been rules prohibiting robots from causing damage to the field. If you have some carpet similar to what is used on the field, I would test anything you design to make sure the mechanism does not dig itself into the carpet and damage it.
FRC 360: 2008-2011
Full-time Volunteer: 2012 - forever
Unread 13-08-2013, 17:46
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Your way of going about it is interesting, though the way I'd achieve what you're talking about its putting what amounts to putting a deployable jack just behind the corners of the frame with plaction tread on the plates that contact the ground. The thought being that you want to get as much of your robot's weight on the highest-traction surface you can.
That and it would just be useful to have built-in jacks on the robot for testing autonomous and such (just have a DIO on the driver-station determine whether the jacks are engaged or not during autonomous)
It's definitely something that we've even thrown around, and worth testing.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
AKA: Spencer Lanman
Hopefully some sort of treading will be sufficient in preventing damage to the field. I'm actually more concerned about drawing fouls from it.
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 13-08-2013, 17:49
AKA: Spencer Lanman
I like the sounds of that. Do you think it would be beneficial to solely support the robot with a jack on both sides of the drivetrain (assuming there's 2 sides) or just in the front or back, etc?
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 13-08-2013, 18:00
Woolly's Avatar
Programming Mentor
Depends on how your frame perimeter. If you put jacks along the sides of the robot, they should be on the longer sides to be the most effective, as surface area is key.
Depending on how much traction you can get without damaging the carpet, it might work either way. A lot of robots that are geared low and have a 4CIM drive right now are capable of pushing with ~200-225 pounds of force. I'd find a good force gauge and see how much it takes to move it and try different tread and add surface area until you're satisfied. Also be sure to weight whatever test platform you use to a realistic robot weight (including bumpers and battery) if it isn't there already.
Unread 13-08-2013, 18:21
AKA: Spencer Lanman
My only opposition to the jack strategy, as opposed to a wedge, is you would be unable to push back if your robot was completely jacked off of the ground.
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 13-08-2013, 18:30
Woolly's Avatar
Programming Mentor
Well, if you're running a mecanum drive you wouldn't be able to push back anyway. With most drivetrains, your best option might be the wedge setup, but keep in mind that you have to overcome the same traction your defender has to overcome to push you to move. Honestly, if you're interested in that setup, I'd look into a butterfly drive or octocanum setup, but that involves deploying wheels which you stated in your OP post you didn't want to have to deal with at the moment.
Unread 13-08-2013, 19:32
AKA: Spencer Lanman
Thank you for the insight, this will be helpful when the team is designing in the coming season, and will give us some ideas to prototype beforehand.
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 14-08-2013, 09:32
Dragonking's Avatar
Dragonking Dragonking is offline
AKA: Aaron Cannon
Dragonking is just really niceDragonking is just really niceDragonking is just really niceDragonking is just really niceDragonking is just really nice
But if you can't push back, the defense is still doing its job by keeping you in place. Especially if you are one of the top scorers. If you aren't, defense shouldn't be a problem anyways
2013-2014 Mechanical Subgroup, Scouting Captain
2015 Design Subgroup, Strategy Lead/Scouting Captain
Unread 14-08-2013, 12:21
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
If you want to get away from defenders, the first thing is a good driver. Watch 118 in match 60 of IRI this year. Our shooter got bent up after hitting 2468(that's what happens when you run into a wall of metal) so we had to play defence for the rest of the match. 217 and us were both defending 118, and they managed to get through us in a matter of seconds.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 14-08-2013, 15:50
AKA: Spencer Lanman
The goal is to use the stilts to play defense ourself, and an agile drivetrain to play offense.
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 14-08-2013, 17:17
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
A sensible and common goal. But I'd suggest watching some more match footage from as many different games as you can, as this goal doesn't really align with reality all that often.
While a mechanical brake will help you maintain position, in most cases there's enough room for a skilled offensive robot to avoid a fixed obstacle (like a team braked in position). Occassionally there are chokepoints (like next to the pyramids this year or the tunnel in 2010), but there are usually other options (under the pyramid this year or over the bumps in 2010) and most of the best offensive robots are capable of using those. If anyting, a braking device will be most helpful for maintaining offensive positioning during a lengthy scoring process in an unprotected area (such as most teams scoring tetras in 2005, tubes in 2007, or a bunch of balls in a single load in 2006).
Similarly, the concept a omni-directional offensive robot seems like it would more difficult to defend, but reality tends to disagree. Unless you have the option of goals in multiple directions (2005), the general path the offensive robot is going to take is predictable, regardless of how many different directions the robot can travel. A smart defender is usually able to position themselves between the offensive robot and their destination and force the offensive machine into at least some contact (a scenario that does not benefit mecanum or omni wheels). If you want to avoid this contact, the solution is typically having a higher acceleration and better drivers than the defender.
