Go to Post You can be extra safe or you can be competative - its your choice. - Raul [more]
Unread 15-08-2013, 15:42
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: pic: 3CIM Ball Shifter
We didn't want a 4 speed, we wanted a 3 speed. We wanted a fast and very fast gear, like our current design goals for high and low, but we had less power, so we needed a low low for pushing (remember this is back before bumpers) and couldn't get away with the fast-low we like now.
But, with the resources we had, it was easier to build a 4 speed than a 3 speed (since we end up with 2 2-speeds in series). The shift patterns are then low/low,low/high,high/low,high/high, with a different ratio spread of each of the 2-speeds in series. But the 2-3 shift (going from low/high to high/low) requires a double-swap shift which is just plain nasty to execute synchronously between two shifters while under power. A possible solution is to run it like a 3-speed with two options for 2nd gear, and essentially jump-shift past the 2-3 shift. This would add complexity to the shift scheduler, although more than 2 speeds already adds complexity to our shift scheduler.
A ball shifter design can do any number of speeds just by adding more gear pairs to the shafts, so it's possible to do a 3-speed instead of a 4-speed, but it's much harder to manufacture than the dual 2-speed with andymark parts or dual 2-speed mesh shifter design (or even the dual 2-speed ball shifter).
So 4 speeds was easier to build, but the 2-3 shift is bad.
Kettering Motorsports
Unread 15-08-2013, 15:54
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
For reference, 222 has been running a 3-speed ball shifter since 2004.
http://www.chiefdelphi.com/media/papers/1539
Unread 15-08-2013, 15:56
Data Nerd
FRC #0079
I thought they'd gone to just running 2 speeds as of late?
Unread 16-08-2013, 12:55
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
This is correct. We only ran 3 speeds in 2004. We didn't find the added complexity and weight to be worth the added gear ratio.
2013 was the first season since 2004 that we haven't made our own transmissions. This season we went with the vexpro ball shifter and will likely use them again in the future FWIW.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
