Go to Post the FIRST season is never over . . it just pauses a while so you can get some sleep. - Stuart [more]
Unread 15-08-2013, 08:52
MysterE's Avatar
MysterE MysterE is offline
FRC Team #3337
AKA: Coach Eiland
FRC #3337 (Panthrobotics)
MysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond repute
Send a message via AIM to MysterE
A few Off Season Questions
Hi all -
It looks like we will end registration of the Red Stick Rumble with eighteen robots. With that in mind, I am considering the best way to run the matches.
Should I run a normal qualification schedule and provide more matches per team? Also, what is probably the best way to run elimination matches without the full 24?
Thanks everyone. It looks like Red Stick is going to turn out to be a great time.
Best -
Daniel
Coach. D. Eiland
Head Coach - Team #3337
Panthrobotics (Woodlawn HS)
2016: Bayou Regional WFFA Winner
2016: Rocket City Regional Judges Award
2015: Bayou Spirit Award, Bayou Chairman's Award, Bayou Dean's List Finalist (Danielle Massey), Bayou Volunteer of the Year Award
2014: Bayou Dean's List Finalist (Witni Widmeier)
2011: Bayou Regional Winner | Judges Award
2010: Rookie Inspiration Award
Unread 15-08-2013, 09:05
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: A few Off Season Questions
Originally Posted by MysterE View Post
Hi all -
Best -
Daniel
I suggest doing a regular schedule and let all 18 teams play in the elims with the top 2 seeds getting byes into the semifinals.
Unread 15-08-2013, 10:01
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
If you only have 18 teams, I would run as many matches as you can, but maybe increase the delay time between matches (I forget what it was this year, maybe it was 12 minutes?) add 2 minutes or so and see how many matches that gets each team in your schedule.
The good news is 18 is divisible by 3, so you can have even alliances for elims (if no one breaks badly). With 6 alliances there are a variety of ways to do it...
1v6, 2v5, 3v4, and then some sort of round robin with the 3 remaining alliances to see who your winner is.
Another possiblity is to basically use the normal bracket but give alliances 1 & 2 a bye directly into the semi finals (since there are no 7 & 8 alliances). This is the easiest if you are using some sort of FMS, as they aren't terribly easy to manipulate. But does mean Alliances 1 & 2 play 2 or 3 fewer matches than the other alliances.
You can also go back to the old days of FIRST and do some sort double elimination type bracket with alliances... so that instead of teams you have alliances. That could be fun & interesting, but would have to be manually tracked and not done on an FMS (I think).
Have a great time!
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 15-08-2013, 10:33
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
At panther prowl last year we had only 22 teams so everyone picked and then alliance 1&2 faced 8&7 in 2v2 matches and if 1&2 won they picked one of the 3 robots on 8&7 respectively to join them. I would not recommend this but if you do instead have 6 "dead" numbers where anyone can pick to have the bye teams and pick from the opposing alliance upon victory
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 15-08-2013, 13:45
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
You could run the event Bunnybot style. There are no scheduled matches, teams just join the que as they are ready to play. This means that you don't have to go to the effort of writing a schedule (stacked matches won't be blamed on the event organizers) and you don't run any matches with dead robots. It will also heavily favor reliable robots.
From a competing team's perspective, it works really well. It also reduces stress when the robot is not working, making repairs safer.
Contact Dale from 1540 if you want full details. I'll post a copy of the full rules when I get home from work.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 15-08-2013, 14:01
Chris is me's Avatar
AKA: Pinecone
If you really wanted to, you could consider doing eight two-robot alliances and two backup teams. It would be an interesting twist on this game certainly, but that's the kind of thing the teams going would probably have to agree on.
Six alliances seems like the way to do it. Four would be better if it didn't exclude a third of the already small event - seems to make more sense to have 3v6 and 4v5, then the winners of those matches go onto regular semi-finals, giving 1 and 2 a bye.
I feel this is a particularly good solution with the serpentine, as it gives the alliances that made the last two picks of the draft extra time to potentially repair or modify their alliance partner.
Unread 15-08-2013, 14:08
AdamHeard's Avatar
Lead Mentor
If you do byes, you should give the #1 and #2 seed the option of passing on those byes to a lower seed.
We've been given byes at a few offseasons, and it's just bummed our team out; we'd rather play more matches.
Unread 15-08-2013, 14:26
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
You could start with semi finals rather than quarter finals. Gives you more time for seeding matches.
Unread 16-08-2013, 00:34
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
As a team going to Red Stick. I think we should make sure we get all the qual matches we can 9-10 or more to make sure we get a good solid ranking. We're also training new drivers so the more practice the better.
We should do 1-6 alliances so no one is left out and snake should be fine with this field of teams. I don't see any supper #6 alliance having a huge advantage here.
1 plays the winner of 4 vs. 5.
2 plays the winner of 3 vs. 6.
I like the idea of passing down the bye.
1->4->5
2->3->6
That way no alliance is punished if they want to play more matches and they just sub into the other alliancess spot in the quarterfinals.
Also I would really love it if we could somehow confirm with teams the week before that they are coming. That way we could possibly do a tentative match schedule. Events with tentative match schedule > than events without.
Unread 16-08-2013, 01:07
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
You could just have 4 alliances of 4 teams but only 3 teams would play each match. This would resolve the issues of having 6 alliances and with only 4 alliances you could also up the number of matches to win from 2 to 3. This would give teams more potential matches to play. And it would likely take close to the same amount of time as an 8 alliance elimination bracket
Unread 19-08-2013, 06:45
kiasam111's Avatar
kiasam111 kiasam111 is offline
AKA: Kiatin
FRC #3132 (Thunder Down Under)
Team Role: Webmaster
kiasam111 is a glorious beacon of lightkiasam111 is a glorious beacon of lightkiasam111 is a glorious beacon of lightkiasam111 is a glorious beacon of lightkiasam111 is a glorious beacon of light
At our off-season (The Duel Down Under) we modified the game so that it was played with 2 robot alliances instead of 3. We had 14 teams, therefore 7 alliances.
QFs
QF2 - 2v7
QF3 - 3v6
QF4 - 4v5
SFs
SF1 - 1vWinner QF3
SF2 - Winner QF2vWinner QF4
F
Winner SF1vWinner SF2
I quite liked having the smaller alliances, because it meant that it was easier for newer teams to find space on the field to play their game. =)
Kiatin - Chairmans Presenter | 2015 Dean's List Finalist
Sydney, Australia
Unread 19-08-2013, 12:10
sarah_storer's Avatar
sarah_storer sarah_storer is offline
Georgia Tech RoboJackets Outreach
AKA: Sarah Storer
FRC #5332 (Toaster Tech)
sarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to behold
As another team participating in Red Stick Rumble, I second the idea for alliance #1 and #2 having a bye to the semis. I ALSO really like the idea of being able to pass those byes to other alliances if they want to play more matches.
Can't wait!
TEAM 3753 BULAH BOTS ALUMNI
2012-2015: Code, pneumatics, and electrical for BULAH BOTS Team 3753
2013: Bayou Regional 1st seed alliance captain and regional winners (With 118 and 4589)
2014, 2015: Bayou Regional semi-finalist
2016-?: Mentor for TOASTER TECH Team 5332
2016: Columbus District 3rd seed alliance captain, semi-finalist; Kennesaw District 3rd seed alliance 1st pick, semi-finalist; Peachtree District State Championship 4th seed alliance captain, quarter-finalist, Industrial Design Award, World Championship qualification
