Originally Posted by techhelpbb
No it is quite doable. Just remember though to add a heated bed to the printer.
Assuming you are printing ABS.
OP, I own a Replicator 2X and it has truthfully been a colossal pain in my rear... of course, we own the same one at work and it seems to be configured properly. I think I need to tinker with it more.
For FRC parts, I would agree that the raw printed plastic is simply not strong enough for anything more than sensor mounts. However, if you are not averse to casting some components it should work well for making masters for silicone molds and pouring urethane casts.
Personally, I went with the 3d printer due to the fact that I don't have a garage of any sort at this point in time. If I did I'd probably have gone with a small CNC mill or a mid sized router capable to handling aluminum. In fact, if I ever do get a place with a garage I will most likely be purchasing the router.
