Go to Post In the encyclopedia of FIRST under the term Encyclopedia it says - See Joe Ross. - rees2001 [more]
Unread 18-08-2013, 17:25
Re: WCD-Belt Driven CAD practice
Andrew, I can assure you (based on my experiences with that design) the bumper mounts are just fine. This is also why we prototype, to find out what breaks!
Unread 18-08-2013, 18:09
JB's Avatar
JB JB is offline
FRC Kit of Parts Engineer
AKA: Jon Bryant
FRC #0238
JB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of light
This looks great. We went to a belt WCD this year and loved it. My big question is with the WCP dual speed. Did you have to increase the size of the spacers and the hex shafts in the gearbox or did the 2 9mm pulleys fit into the basic gearbox. Also did you use the regular or the WCD model.
My posts are solely my own and do not necessarily reflect the views or opinions of FIRSTŪ or my affiliated team.[/center]
FRCŪ Kit of Parts Engineer: 2014-Present
Team 238: 2016-Present
Team 1403: 2008-2014
Unread 18-08-2013, 18:29
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Due to the belt pulleys being larger than sprockets, the gearbox will have to be widened by about half an inch +/- .125". Although it will take some machining to get this done, (some very basic machining) I see it as a benefit rather than a hassle. With belts rather than chains, after they are set since it is exact c-c you never have to touch them again unless something bad goes wrong. like thrown belt or ratcheting occurs or other issues caused usually by human error. I forgot to mention I added .003" to the c-c distance to get the tight fit on the belts. But I have seen some very good and bad things said about belts. Mainly good. So I am giving them a shot. I put the WCP WCD gearbox in there because it was built for the type of frame I designed so it was basically a plug and play. I guess you could try and use the regular WCP shifter but I didn't. Glad I could help.
Unread 18-08-2013, 18:49
Smile Re: WCD-Belt Driven CAD practice
To be clear, Damprobot, this is all for a prototype to test out some sponsors we found for Cooper's fantastic team.
I have high hopes for their team, Cooper is awesome at absorbing information from all over and learning very quickly. They are also backed by some former mentors of 57 and 624.
Unread 18-08-2013, 19:19
Cash4587's Avatar
AKA: Cooper Cash
We are also backed by people like you who are always willing to help
Unread 18-08-2013, 19:22
Cash4587's Avatar
AKA: Cooper Cash
http://prntscr.com/1m24bi
I was doing some more messing around and found that if WCP would have made their gearbox a little more than an 1/8th of an inch wider maybe more like 1/4", we could have fit 5mm gt2 pulleys in there that are 9mm wide. It is so close. I wish WCP would just make a version of their gearbox for people like us who like to use belts...
Unread 18-08-2013, 19:28
Cash4587's Avatar
AKA: Cooper Cash
http://prntscr.com/1m25qt
Yet again, I did some more updating to make the bumper mounts legal (the distance between them was not <= 8in.) and I made their flanges beefier. Lastly, I widened the frame an inch and a half on each of the end tubes to better use all of the frame perimeter rule except 1 inch of it. so the frame perimeter is now 111" vs 108"
Unread 18-08-2013, 22:18
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
We did the almost did the same thing, belt drive WCD with WCP gearboxes.
We were able to fit 9mm GT2 pulleys in there no problem.
http://31.media.tumblr.com/624ace34b...cgvo7_1280.jpg I personally machined the pulleys out of 3/8 alum plate.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 18-08-2013, 22:20
Haha Mark I've been showing him your stuff the entire time for this project
Unread 18-08-2013, 22:41
Cash4587's Avatar
AKA: Cooper Cash
OHHHH. This is the team with that drive that pushed that robot the whole field length. That was sick.
Unread 18-08-2013, 22:50
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Yeah, that was kind of an uncanny resemblance...
But I suppose once you decide to use belts and colsons in a WCD, they're not many choices left to make.
-Plutarch
Unread 19-08-2013, 01:08
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Cooper,
You should ask your sponsor if they have the proper brake dies to bend your bumper brackets from one piece. They would need to use a large goose neck die or make a window in the die set for the return flange. Otherwise great design. You could bend in hat sections into the belly pan for air lines and wiring. I haven't seen many designs that incorporate access from the bottom of the robot.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 19-08-2013, 09:47
Cash4587's Avatar
AKA: Cooper Cash
Originally Posted by roystur44 View Post
Cooper,
Oh yeah they have plenty of ways to get it done, they use multiple cnc pan and brakes in their shop and have tons of capabilities to do things like this. I will be sure to check again. I have been in constant contact with them and I am always talking with the shop and company owner. Since I am out of Houston, Texas, we have some of the finest shops in the world due to the large oil industry just south of us in the gulf and surrounding area.
Unread 19-08-2013, 04:15
Mk.32's Avatar
AKA: Mark
Oh awesome
We were really happy with how our 2013 drive came out. Let me know if you have any questions.
Unread 19-08-2013, 03:38
ablatner ablatner is offline
AKA: Andrew Blatner
ablatner is on a distinguished road
I can't quite tell from the angle, but is there enough room for mounting hardware on the bumper mount flanges? The sets of holes on the inside of the flange look really close to the bend. You may not be able to get a rivet gun in there.
2009-2013: Student, Team 100
2013-????: ?
