Go to Post I was surprised how easily Mike hoisted me off the ground. I'm nearly 250 pounds and he lifted me up like I was a soccer ball! :ahh: - Koko Ed [more]
Unread 21-08-2013, 12:51
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
Java equivalent of NI demo vision project
We did vision for the first time last year, am looking at moving to Java this year.
One thing that was very helpful last year was an NI provided sample on the PC where you access the camera and manipulate the parameters for the recognition software via sliders in real time, and get a real time view of the scene with the recognized particles highlighted and numeric information overlaid. Made it very easy for the students to see what the various parameters actually do.
Looking at writing SmartDashBoard/OpenCV based detection, so I'd like to have something similar to make it easy for the students to visualize what the various pieces of Java code do. I'm looking at Team 341's 2012 code, and it can optionally display intermediate results, but the adjustable parameters are not there.
Has anyone already seen/done this, or am I going to have to roll my own up? The interactive aspect is what's missing.
Unread 21-08-2013, 22:26
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: Java equivalent of NI demo vision project
It's quite doable using SmartDashboard Properties. My team's 2013 vision system used this, and it made calibrating thresholds wonderfully easy. I'll be playing with our usage of these properties during this preseason to see if I can make the system nicer and more flexible, but the current version shows the basic concepts of it.
One thing you might notice is the obnoxiously large propertyChanged() method, and all the variables storing the values from each of the properties. This was a hack I made to avoid using the Property.getValue() method, which I had blamed for some previous performance problems. This hack got a bit out of hand however, and I'm not totally sure whether it had any positive effects. A big part of making this "nicer" is figuring out how to eliminate that obnoxiousness without causing any performance problems, which may be as simple as using getValue().
I code stuff.
Unread 22-08-2013, 18:50
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
Hey Joe i was wondering if its possible for you to comment some of your code? That would be great instead of trying to guess what certain things are.
Unread 23-08-2013, 09:25
Ginto8's Avatar
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
I'm working on that. I apologize that it's a mess; I focused on making it work, not on making the code easily readable. I'll be refactoring it significantly during this preseason.
I code stuff.
Unread 23-08-2013, 14:52
tuXguy15's Avatar
Team Mentor
AKA: Devin Kolarac
Thanks so much
