Go to Post Expect a lot of noise, unexpected things going wrong, and most of all, tons and tons of fun. - nitneylion452 [more]
Unread 21-08-2013, 15:01
Re: Stepper Driver to CIM
My point is that the accuracy of the CIM motor is dependent on the brush spacing and the size of the brush assy. The CIM has approximately 6 distinct positions (steps) per rotation or 60 degrees +/- 90 degrees per step (based on the brush contacting two commutator segments +/- 1 segment). In a rough calculation using the above example of 100:1 reduction, the per step accuracy of the CIM would produce about 0.0004" +/- 0.0006" per step at the output of the lead screw or 0.1" +/-0.25" for 1 rotation of the lead screw, worse case. The 1.8 degree stepper as shown above will produce as described 0.0005" +/- 0.00002" per step or 0.1" +/-0.004" per rotation, worse case. While it is possible to produce better accuracy in the CIM in a closed loop configuration and with higher reduction ratios, there is a diminishing return on investment. This example does not take into account the accuracy of angular position within a 100:1 transmission and assumes it to be infinitely accurate.
