Go to Post Never mind the imperial British Empire, the sun never sets on our FIRST season! - artdutra04 [more]
Unread 23-08-2013, 15:02
T^2 T^2 is offline
FRC #5499
Re: 6 wheel holonomic drive feasibility
Let's break down your response.
Thanks for your reply. The reason we're trying to push with a mecanum drivetrain is that "not having enough traction and power" is the only argument anyone on my team has made against getting mecanum wheels (and they're saying it a lot).
The "traction and power" issue has largely been addressed already in this thread. To sum up, traction in the forward and reverse direction is not significantly weaker on mecanums compared to standard wheels, and forward/reverse power is reliant only on the motors and gearboxes. In the sideways direction, of course, mecanums lose out in both. (There are many threads explaining why this is.)
If there's a way to have both in addition to holonomic steering, there would be no reason not to get the wheels (besides price and assembly and possibility that it won't help at all and whatnot)
You're completely wrong. Not only are there significant mechanical downsides (weight, size, complexity, number of gearboxes required) to mecanum, but they also come with a huge opportunity cost. The time and money you waste on those things could be much better spent training your students to make a drivetrain that works, and what's left over can be spent on the rest of your robot.
Unread 23-08-2013, 15:43
For properly operating mecanums (e.g. rollers can spin freely etc), and for the same tread material, mecanums have less traction in the fwd/rev direction than a standard wheel.
Unread 23-08-2013, 18:12
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Loving your enthusiasm. I'm pretty sure I covered all my bases in my previous response in the parenthesis
(besides [...] the possibility that it won't help at all and whatnot)
Whatnot means I'm not sure of what will happen. Also, we already have the wheels, it's just whether or not we want to use them that's an issue.
I'm getting the feeling that you have something against mecanum wheels... well, to each his own :) We have plenty of drivetrains that work, and even more people who know how to use them. Teams that decide to use mecanum wheels have to start somewhere, right?
Unread 23-08-2013, 18:54
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Originally Posted by ekapalka View Post
I'm getting the feeling that you have something against mecanum wheels... well, to each his own We have plenty of drivetrains that work, and even more people who know how to use them. Teams that decide to use mecanum wheels have to start somewhere, right?
My opinion (and I think his opinion, and the opinion of many people on this forum) is that just because you can build a mechanum drive doesn't mean you should. Maybe your team thinks differently, and thats perfectly fine. But the point was that the resources you put into a mecanum drive would be better spent on improving either your tank drives (no tank drive is perfect, there is always room for improvement) or the other mechanisms on your robot. Again, thats an opinion, and like you said, to each his own.
If you have want your robot to have pushing power, mecanum is definitely a terrible choice (this is an opinion backed by a lot of evidence). The are drivetrains out there that can give you omnidirectional movement and pushing power (swerve, octocanum, and probably some other rare ones), but only the best teams (think IRI caliber) are able to make one without devoting nearly all their resources to it. Generally, unless your strategy to play a certain year's game revolves completely around omnidirectional movement with pushing power, you should just stick with tank drive (or mecanum if you really insist). (I'm addicted to parenthesis (like, really addicted)).
Unread 23-08-2013, 19:49
Nate Laverdure's Avatar
FRC #2363
Now is the perfect time to build a mecanum drivetrain. Your experience may differ, but I couldn't understand mecanum's bad reputation until I built my own version and saw firsthand how the drivetrain's actual behavior differed from the way I'd imagined the system would behave. If you get it done in the next 4 months, you'll be able to carry all of your "lessons learned" into the 2014 build season.
Unread 24-08-2013, 10:45
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Mecanum wheels are a wonderful exercise and learning experience for a team. If you guys want to experiment with them I say go for it.
When it comes to winning matches however, remember that the game should decide what type of drive you use, a mecanum drive might not match the game. We have done it once with great results and I could see them being very helpful in one other season I have participated in, that's 2 out of 9 seasons for me.
Unread 24-08-2013, 13:44
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Which two games? I assume 2011 is one of them.
Unread 24-08-2013, 22:49
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
How about this: a 6-8 CIM drivetrain (not necessarily FRC legal) made for pushing (i.e just throw on some extra motors for forward pushing). That HAS to add at least some additional pushing/pulling power, regardless of how much traction mecanum wheels have (for all intensive purposes, the mecanum wheels could be plaction wheels).
The thing about mecanums and omnis is that they are designed to slide. That, in fact, is the defining aspect that makes them different from any other wheel. That extra omni might help you push forward and backward(emphasis on 'might'), but it will be absolutely useless pushing sideways because the rollers are passive. If you want to have omnidirectional drive that can push, you have 2 options: swerve or octocanum. And, in order for either of these options to be effective at pushing, you have to execute the design flawlessly. You are right, more motors adds more pushing power(if you do it right) but most of that power will be negated by the fact that the wheels are designed to slide around.
I feel like I remember seeing Karthik posting something that was very similar to this... Anyway, I agree fullheartedly. In addition to what you mentioned here, they also can have some severe mechanical issues. We did mecanum once, back in 2010 (first and last time doing holonomic). Somehow, something got bent so we could only strafe. That was also the heaviest, the least reliable , and the most complicated drivetrain we have ever built.
In my opinion, if you want to do a holonomic drive, mecanum is possibly the worst option. The wheels themselves are expensive, it offers no potential for pushing, and it is a nightmare to program. A well-executed tank drive and a decent driver will maneuver just as well as a typical mecanum drivetrain. If you really, desperately want to do holonomic drive for some reason, I would suggest either swerve or octocanum. Remember, both of these are extremely complicated, weigh more than tank, and without a good driver they will not make your robot any better.
How many bots that won champs/IRI used mecanum? None.
How many bots were even on Einstein that used mecanum? None.
How many mecanum bots were invited to IRI? One, and it was probably the best executed mecanum drive this year.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 24-08-2013, 22:56
Originally Posted by evanperryg View Post
[mecanum] is a nightmare to program
Could you elaborate a bit on that? What did you have in mind?
Unread 24-08-2013, 23:43
ekapalka's Avatar
FRC #3216
[...] and it is a nightmare to program.
The only thing that makes me feel any better about programming mecanum wheels is this information (courtesy of Ether; thanks, by the way) and the mecanum classes in WPI (we're using C++), which I have been reading over and over since I found out we had the mecanum wheels (that doesn't mean I should rely on it, but it gives us hope that we can program it). We already have four wheels, four gearboxes, four motors, and four Talon SRs, all with no dedication at the moment. We're currently designing the chassis with room for a central gearbox (see original post), not necessarily for omni wheels, but for the possibility that we go back to skid steering. Hopefully it'll be water or plasma cut from sheet metal, so adding in additional holes for such things won't be that much more difficult (if we're getting it water-jet. If it's plasma cut it won't quite be as easy). Thanks for your input, by the way :)
Unread 25-08-2013, 12:42
Oblarg Oblarg is offline
AKA: Eli Barnett
Mecanum is not a nightmare to program. It has been done many times before; the knowledge is there, and so is the code itself if you wish to download it. It becomes somewhat harder if you want field-oriented control, but the difficulty there is with the gyro, not with the actual drive.
Mecanum is a fairly good, cheap solution to the omnidirectional problem. It is not a 100% solution; it has notable shortcomings (effectively lower coefficient of friction than traction wheels with the same material, lots of frictional losses when moving sideways, losses due to imperfections in wheel design/construction), but also notable benefits (ease of construction, ease of maintenance, relatively low cost). It is not going to compete with a swerve drive or with a hybrid drive, but it will give you an agile robot (acceleration in FRC, with the exception of 2009's silly teflon wheels/driving surface, has never been traction-limited) and that can strafe. For some games, this is all that is needed; 449's use of mecanum in 2008 was a huge asset for our team, as the anti-roadblock rule in that game made the lack of pushing power a near non-issue. For others, it is not.
"The breakfast of champions!"
