Go to Post Once you go hex you'll never go back. - sdcantrell56 [more]
Unread 25-08-2013, 12:49
Re: Encoder problems
Originally Posted by Peleg2230 View Post
Should I replace back the encoder to the E4P that probably will work around those speeds?
The E4P should work, if you physically connect only one channel and set it up as a counter. For a 360 CPR E4P, I recommend you try changing the blue "5" to "126" for high speeds (like 6000 RPM) to reduce the noise.
