Go to Post Finding those students and giving them a lift up out of the sea of apathy that is constantly trying to drown them is one of the reasons I am in my profession. - Ben Mitchell [more]
  #31   Spotlight this post!
Unread 25-08-2013, 13:34
Peleg2230's Avatar
Peleg2230 Peleg2230 is offline
FRC #2230 (General Angels)
Peleg2230 is an unknown quantity at this point
Re: Encoder problems
I recommend you try changing the blue "5" to "126" for high speeds (like 6000 RPM) to reduce the noise.
I'll try that but aren't your calculation showed that it is over the FPGA limits?
General Angels #2230 :
2009 IS champions + chairman's award
2011 IS finalists
  #32   Spotlight this post!
Unread 25-08-2013, 15:27
I'm not sure where you got that from. Here is the calculation I posted (with bold added for emphasis):
A US Digital 360 CPR E4P encoder outputs 2*360 = 720 total edges (360 rising + 360 falling) per rotation on each channel. So for each channel, an edge transition occurs every 1/720 of a rotation, if the symmetry is perfect (see attached excerpt from datasheet).
When using just a single channel of this encoder as a counter, and assuming perfect phase symmetry, speeds greater than (1/720)/(6.525e-6) = 212.9 rotations/sec = 12,771 RPM would cause a problem for the FPGA1.
But the symmetry is not perfect. According to the datasheet, the symmetry across the range of recommended mounting tolerance can be off by as much as 75 electrical degrees. So instead of being (1/720) of a rotation apart, some of the edges in a channel could be as close as (1/720)*((180-75)/180) of a rotation apart. So speeds greater than (1/720)*((180-75)/180)/(6.525e-6) = 124.2 rotations/sec = 7,450 RPM would cause a problem for the FPGA.
  #33   Spotlight this post!
Unread 25-08-2013, 15:40
Peleg2230's Avatar
I'm still using the AS5145B and as you can see in the graph we reached the limit, When I will change it back to the E4P there won't be any problem.
Thank you very much for all the help and knowledge!
2011 IS finalists
