Go to Post I guess it's true, 'There is no replacement for displacement'. - Andy A. [more]
Unread 24-08-2013, 11:12
Oblarg Oblarg is offline
AKA: Eli Barnett
Attaching Plaction Tread to Delrin Cylinders
So, for one of our off-season projects our team is manufacturing custom traction wheels out of delrin and plaction tread. I had heard that the best/easiest way to do this is imply to attach the tread to the delrin via. wood screws, but I'd like to get some additional input before we actually attempt this as it's not something I've done before.
Could anyone with experience doing something like this offer some advice on how best to do it?
"The breakfast of champions!"
Unread 24-08-2013, 11:27
Aren Siekmeier's Avatar
on walkabout
Re: Attaching Plaction Tread to Delrin Cylinders
I would suggest tapping some holes in the delrin hub and fastening the tread with machine screws, like button head phillips or something that you can easily take in and out with a power drill. This is what we did this year with our 3d printed ABS wheels. Beats rivets when it comes to maintenance.
Unread 24-08-2013, 11:33
AKA: Eli Barnett
Thanks a bunch for the advice. So, you'd recommend using a tap rather than just a pilot hole and a self-tapping screw?
Unread 24-08-2013, 11:35
Chris is me's Avatar
AKA: Pinecone
Honestly, either would work just fine. You'll change thread a few times per season at most depending on what material you get.
Unread 24-08-2013, 13:12
DonRotolo's Avatar
Back to humble
FRC #0832
Agreed, either is fine, but by tapping the threads you get better threads and holding power, and gain re-usability well in excess of what self-tapping screws can provide. Plus machine screws have a wider variety of head profile available.
Tapping in delrin is easy.
Unread 26-08-2013, 08:34
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
What Don and Chris both said. Don's post also reminded me of my love for Delrin, it's so nice to work with.
Back on topic though, should you ever see or feel the need, you can also look into installing threaded inserts into the wheel, either a knurled press in type insert or a riv-nut should work pretty well. Only way I can see you having issues with threading right into the delrin wheel is if you have to change tread frequently and use a drill. If you don't start the threads by had (always start the threads by had) you could risk damaging/destroying the treads.
-Dustin Benedict
Unread 26-08-2013, 18:17
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
We have been using tiny wood screws on UHMW wheels for many years and have never had any issues. We also did this on Delrin rollers last year, makes replacing the tread very easy.
When we replace the tread we attach it again in a different spot and never have to worry about lining up with any existing holes. Works great.
We actually make Aluminum wheel "rims" and an outer disk of UHMW just so we can easily replace the tread using small wood screws. All you need is about 1/4" of material and maybe 6-8 screws per wheel.
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 03-09-2013, 22:22
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Reading through the posts, I was wondering what you guys would suggest to use for a head type. I was thinking a hex head tek screw wouldn't be ideal because you'd have the bump sticking out from your wheel. This makes me think counter-sunk screws would be the best. However, since counter-sinking plaction tread would be pretty hard, would just plowing the screw into the tread until it's level do? It just seems like head type could be an issue.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 03-09-2013, 22:35
Billfred's Avatar
Billfred Billfred is online now
We've always done it with short wood screws when we couldn't rivet; we've never needed to change them enough times over a robot's service life that it was necessary to be fancier.
Unread 04-09-2013, 16:05
AKA: Dave
We use small phillips screws or flat head wood screws. No need to counter sink. Once you screw it in the head of the screw will hide under the rubber pretty nicely.
Unread 04-09-2013, 21:43
DonRotolo's Avatar
Back to humble
FRC #0832
Agreed. It doesn't need to be flush, just lower than the rubber. Try a flat head, or maybe a Truss or Flat Filister.
Unread 05-09-2013, 03:34
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
You should try low profile drilling screws
Mcmaster 94090A100 or 92715A320
They are almost like a pop rivet but are removable
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
