| Thread Tools |
Rating:
Display Modes |
Inventor 14 VBA Failed to Initialize
I just downloaded the Inventor Pro 14 student software off their educational site, and when I start up Inventor I'm greeted with the following message:
Except restarting helps nothing, and neither did installing. Help? Last edited by CalTran : 27-08-2013 at 10:20. Reason: Added information |
Re: Inventor 14 VBA Failed to Initialize
When you say you go to run Inventor, do you mean you go to run the installer, or is it already installed and you go to run the actual program?
I can't remember what the error said, but when I downloaded it I moved the installer .exe file to my desktop from my downloads folder. It wouldn't let me install it because I moved it. I had to redownload it and try it again (moving the installer back to the downloads folder does not work). |
*Edit* At the moment I simply downloaded Inventor 13 for use. Last edited by CalTran : 27-08-2013 at 11:27. |
Do you have Microsoft Office installed and if so which version?
Have you tried to open the VBA editor in Microsoft Excel or Word? |
I had some troubles installing Inventor 2014 but I think it was on my end, not theirs. As for running after the install it seems to work fine.
#7
I had major problems installing Inventor 2014 (and 2013). It was caused by an improper .NET Framework 4.0. Factory resetting my computer worked like a charm :)
#8
My setup information: OS: Windows 8 Processor: Intel Core i7-4770K @ 3.5GHz System: 64-bit Graphics: 2 MSI 7950s running CrossFire X Memory: 16gb (8x2) Ripjaw X series Autodesk Inventor Pro 2014 installed fine(?) both times, as well as repaired fine(?). I put ? after both fines because there were no prompted errors in these operations. |
#9
Bet you will get the same error if you try to open that.
#10
And, er, how would I go about trying out this test?
#11
I've had the same issue in the past. It was a new version of Microsoft Office that was the culprit. It seems to want to argue with Inventor. Something about how Office runs VBA in it's own little environment or something like that. Look for VBA7.msi in your Inventor installation media (You may have to download it from Autodesk, but not follow through with installation again, because I think the default behavior after installing Inventor is to delete the installation files). Install that and Inventor should run fine (for now). I've heard opening an Office application will undo your progress and you'll have to reinstall the VBA7.msi every time, but I can't confirm that. Apparently it's a known issue and Autodesk and Microsoft are working together on a solution. In the mean time, the customer loses.
![]() Good luck |
#12
Just be glad you didn't get French for a spell checker (not kidding that was an actual Office bug). To start VBA in Microsoft Word or Excel: Open either program. Press these keys at the same time: ALT F11 Bet you get an error instead of the VBA editor. |
#13
Interesting that it works at all. Probably have the older version. As pointed out above try to search for your VBA7.msi file. Run that. |
#15
I ran into the same exact problem. I've been using Solidworks and Creo while I wait on a solution from Autodesk/Microsoft.
