Go to Post 5:20 - Lots of discussion about how FIRST pretty much wipes out the world of at least one object every year. - Andy Grady [more]
Unread 27-08-2013, 10:09
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Inventor 14 VBA Failed to Initialize
I just downloaded the Inventor Pro 14 student software off their educational site, and when I start up Inventor I'm greeted with the following message:
Originally Posted by Serious Error
VBA failed to initialize properly. Please restart Inventor.
(Specifically I need to close the error 6 times, so I imagine that means it's occurring 6 times.)
Except restarting helps nothing, and neither did installing. Help?
Academic Student (Forever)
Unread 27-08-2013, 10:51
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: Inventor 14 VBA Failed to Initialize
This might help:
http://forums.autodesk.com/t5/Autode...r/td-p/3543758
Unread 27-08-2013, 10:58
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
When you say you go to run Inventor, do you mean you go to run the installer, or is it already installed and you go to run the actual program?
I can't remember what the error said, but when I downloaded it I moved the installer .exe file to my desktop from my downloads folder. It wouldn't let me install it because I moved it. I had to redownload it and try it again (moving the installer back to the downloads folder does not work).
J Wallace IV
Truck Town Thunder
Just a college student now.
Unread 27-08-2013, 11:20
CalTran's Avatar
MST Rolla Senior
I mean go to run inventor itself. I already installed the program.
*Edit* At the moment I simply downloaded Inventor 13 for use.
Unread 27-08-2013, 11:28
techhelpbb's Avatar
Do you have Microsoft Office installed and if so which version?
Have you tried to open the VBA editor in Microsoft Excel or Word?
Unread 27-08-2013, 11:48
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
I had some troubles installing Inventor 2014 but I think it was on my end, not theirs. As for running after the install it seems to work fine.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
Unread 27-08-2013, 11:53
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
I had major problems installing Inventor 2014 (and 2013). It was caused by an improper .NET Framework 4.0. Factory resetting my computer worked like a charm :)
Unread 27-08-2013, 15:17
CalTran's Avatar
MST Rolla Senior
I have not tried opening the VBA editor in Excel or Word
I haven't had any issues running the installer. My issue is trying to run Inventor 14 itself.
My setup information:
OS: Windows 8
Processor: Intel Core i7-4770K @ 3.5GHz
System: 64-bit
Graphics: 2 MSI 7950s running CrossFire X
Memory: 16gb (8x2) Ripjaw X series
Autodesk Inventor Pro 2014 installed fine(?) both times, as well as repaired fine(?). I put ? after both fines because there were no prompted errors in these operations.
Unread 27-08-2013, 15:31
techhelpbb's Avatar
Bet you will get the same error if you try to open that.
Unread 27-08-2013, 16:12
CalTran's Avatar
MST Rolla Senior
And, er, how would I go about trying out this test?
Unread 27-08-2013, 16:25
Michael Hill's Avatar
I've had the same issue in the past. It was a new version of Microsoft Office that was the culprit. It seems to want to argue with Inventor. Something about how Office runs VBA in it's own little environment or something like that. Look for VBA7.msi in your Inventor installation media (You may have to download it from Autodesk, but not follow through with installation again, because I think the default behavior after installing Inventor is to delete the installation files). Install that and Inventor should run fine (for now). I've heard opening an Office application will undo your progress and you'll have to reinstall the VBA7.msi every time, but I can't confirm that. Apparently it's a known issue and Autodesk and Microsoft are working together on a solution. In the mean time, the customer loses.
Good luck
Unread 27-08-2013, 16:34
techhelpbb's Avatar
Good luck
Yeap that's the exact issue I linked earlier.
Just be glad you didn't get French for a spell checker (not kidding that was an actual Office bug).
To start VBA in Microsoft Word or Excel:
Open either program.
Press these keys at the same time: ALT F11
Bet you get an error instead of the VBA editor.
Unread 27-08-2013, 16:39
CalTran's Avatar
MST Rolla Senior
Well for Microsoft Office University 2013 Word I got what appeared to be a VBA editor rather than an error.
Unread 27-08-2013, 18:04
techhelpbb's Avatar
Guess I lost that bet
Interesting that it works at all.
Probably have the older version.
As pointed out above try to search for your VBA7.msi file.
Run that.
Unread 27-08-2013, 20:20
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
I ran into the same exact problem. I've been using Solidworks and Creo while I wait on a solution from Autodesk/Microsoft.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
