Go to Post That's is why I raised this question, becuase I do not know all the facts (I doubt anyone does). - Ken Leung [more]
Unread 29-08-2013, 16:40
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
What do we do with legacy cRIO when we get Athena?
What support or options will we have for using our cRIO hardware when Athena becomes the FRC controller?
Many teams have multiple controllers for use on practice bots and instructional robots. What programming options will we have going forwards for this hardware?
I'm most familiar with WindRiver, since we programmed in C++, and I worry that we will not have licenses for the workbench environment on the cRIO afterr Athena debuts. I suspect there are similar issues with cRIO labview or Java support.
I think I would like to see an open source OS with a selection of programming interfaces available so that we can continue to make use of the legacy hardware as long as it continues to function.
Maybe we could even get support for custom programming the FPGA, since the controller would not be legal for FRC competition anyway.
I would really hate to see all that hardware turn into bricks and recyclable electronics parts.
Unread 29-08-2013, 17:01
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Re: What do we do with legacy cRIO when we get Athena?
...You mean basically like most of the old IFI stuff?
Unread 29-08-2013, 17:24
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
you can still use it. the new one is is software compatible, lighter, and cheaper.
Ed Barker
Unread 29-08-2013, 17:27
Chris is me's Avatar
AKA: Pinecone
The old IFI stuff didn't necessarily rely on software licenses that expired. The problem here is that while we'll all have cRIOs, will we be able to do anything with them after 2014?
Unread 29-08-2013, 18:05
magnets's Avatar
magnets magnets is offline
I know that Java doesn't need any licensing to run, but I really hope that the new stuff is backwards compatible. Our team currently has 3 crios that we can drop into 6 different robots (09-13 plus a practice 2013) and have working instantly. This is a really valuable resource for us, as we can prototype with wide, long, 6wd, 8wd, 4wd, swerve, and meccanum wheels really quickly. If the cRIO's are no longer usable, we'll have some trouble.
As for the IFI systems, they aren't useless. We have 1 robot that is from before 08 that is all set to go, we just need to turn on the breaker, and plug in the OI and it will start. We also have a laptop with mplab, the compiler, and the ifi downloader that we can use if needed.
I will be slightly upset if on our old robots our team needs to replace cRIOs (released 2009) with IFI controllers (released 2005) in order to keep them going after we get robotrio.
Unread 29-08-2013, 19:56
The goal is for the SW tools given out in future years to support roboRIO and cRIO controllers -- at least for a transition period. Changes made to WPILib may mean that old code needs a few tweaks to work with the new SW tools, but ideally, you simply recompile.
Things like the driver station and dashboards may undergo enough changes so as to have an old and new version that are both present on the system.
I also suspect that some of the legacy SW tools will be made available, particularly if you ask and explain the value in it. I'd love to see the FPGA tools be made available as well, but that is not getting much attention at the moment.
Greg McKaskle
Unread 30-08-2013, 11:30
ericand's Avatar
AKA: Eric Anderson
That is good to hear.
My biggest concern is the licensing aspect. As official support tapers off, and moves to the more modern hardware, I don't want to be dependent on time locked licenses for the tools needed to program the legacy hardware.
Do we need a project to create a replacement for vxWorks as the cRIO base OS?
Do we have enough info to make such a project practical?
Greg McKaskle
Unread 30-08-2013, 11:42
vxworks doesn't have a time locked license, so you don't have to replace it. Windriver Workbench does. People have already been working on gcc compilers. See http://firstforge.wpi.edu/sf/projects/c--11_toochain
Unread 30-08-2013, 12:41
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
I would assume the cRio will maintain compatibility with later LV releases, so you could probably hold on to them and use them on things like robots from past seasons or prototypes.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 30-08-2013, 14:37
ebarker's Avatar
AKA: Ed Barker
This isn't the official word but I'm betting strongly you will be able to use the new or old system.
Ed Barker
Unread 30-08-2013, 15:19
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
They did announce that all teams will receive a RoboRio in their 2015 KOP so my bet is that it will be the only competition legal controller for that and the following seasons just as they did when the CRio replaced the IFI system. Again that is not official just my belief based on the currently available information and how things played out in the past.
Unread 30-08-2013, 16:48
Isaac501 Isaac501 is offline
FRC #0501 (The PowerKnights)
Rookie Year: 1995
Isaac501 is just really niceIsaac501 is just really niceIsaac501 is just really niceIsaac501 is just really nice
Nothing in the Java toolchain has a time-restricted license. If bad comes to worse, learn another language.
Team 501 Academic Advisor, Systems Build Mentor
Unread 30-08-2013, 17:12
AKA: Pinecone
I think Ed meant that teams will be able to operate both control systems (e.g. at home), as opposed to competing with either system.
Unread 30-08-2013, 21:15
Mr V's Avatar
FRC #5588 (Reign)
That is not the way I read it. Certainly you will be able to continue to use it at "home".
