Go to Post Has FIRST ever made a game that was easy to do? - Koko Ed [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 28-08-2013, 22:35
Professional Stat Padder
Re: Best Theoretical Alliance
Originally Posted by KrazyCarl92 View Post
The alliance that would best maximize points scored would have to be 254, 67, 1114. This alliance doesn't leave any climb points on the table, could get all 6 colored discs into the pyramid, and also has a 7 disc auto in addition to 1114 blocking the center line from most center line auto modes. Add 67's FCS to an alliance that already has 3 solid teleop scorers and they could consistently empty their feeder station of discs, and accurately too.
Switching out 1114 or 67 for a robot that can get the center line but doesn't climb above 10 would sacrifice 30 points to gain 12.
Switching out 254 for a robot with a more accurate 7 disc auto would be sacrificing 20 points in climbing for maybe a 6 point auto advantage on average.
In teleop, all that matters is emptying your feeder station as consistently as possible and scoring some of your opponent's misses, and this alliance could already do that very well. This means it would make little sense to switch any of these robots out for another robot based on teleop performance because there would be almost no marginal gain in overall alliance teleop performance, but it necessitates sacrificing plenty of points elsewhere.
The only possible sub I would make, Carl, is 254 for 1986. But only because 1986's auto is better. That being said, 1986 doesn't sweep the floor nearly as well as 254 does, so picking up misses could be a problem, and make you alliance just as good.
(2015-Present)
Unread 28-08-2013, 23:57
LeelandS's Avatar
LeelandS LeelandS is offline
Robots don't quit, and neither do I
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
Okay, I'll play!
1986, 1114, 67.
1986 boasts a 7 disc autonomous and a 30 point climb, plus being one of the best disc scoring robots of the year. Their do-all robot makes them my first pick.
1114, while being famous for their climb, also developed a cycling ability that rivaled their counterpart, 2056, albeit not quite as accurate. A 3 disc autonomous, 5/6 cycles, and the 50pt climb and dump makes 1114 a sure pick.
67, while a pick that is being heavily scrutinized, is a worthy pick. 67's FCS drew heavy defense when they were the highest scoring robot on an alliance. On this alliance, all 3 robots are defense-worthy threats. Even if the full court shooting is neutralized, they are a consistent cycler, as well as boasting a 40pt climb and dump (assuming 1114 does the 50). In addition, 67's dominant position in the corner will prevent too much traffic on the center of the field, giving 1114 and 1986 more room to maneuver.
Potential Autonomous points: 42 + 18 + 18 = 78
Potential Teleop Points: Um... Pretty fair to say all 45 discs could be scored in this one. 67/1114/1986 are all reliably accurate, and 1986's floor pick up could retrieve any misses. So we'll say...
(3*45) = 135
+ (3*6) for the discs on the ground by the opponent is 153.
Potential Climbing Points: 30 + 30 + 30 + 50 (for the pyramid discs) = 140.
78 + 135 + 140 = A Whopping 353 (335 if we don't include discs preset on the floor not scored in autonomous). And I firmly believe this alliance could consistently get at least close to that.
My heart will forever lie with SparX
1126: 2008 - 2011; Where it All Began.
1405: 2013 - Present; A Wanderer is Born.
Work hard, play hard. And maybe someday...
Unread 29-08-2013, 00:32
xForceDee's Avatar
xForceDee xForceDee is offline
AKA: Bart Kerfeld
FRC #4239 (Warpspeed)
xForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to behold
Forgot about their 30 point climb. My only concern with picking them over 2056 is if all of these robots actually fit at the top level (I have never actually seen more than one robot up there at a time).
254 and 987 are teams I didn't get to see as much as I now hoped I had. 469 was a team I also greatly considered. Still, like I said, there is no real right answer.
Thanks to everyone who posted, it was great to read your input.
Unread 29-08-2013, 09:18
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
If we can have a legitimate debate on this over multiple pages of multiple threads then props to the GDC for doing their job. Its great that this game has so many strategies that even now we have trouble figuring out the best way to play.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 29-08-2013, 10:06
1986 climbs the inside of the pyramid, while 67 and 1114 climb the corners. All three would very well fit.
I'd like to see 1986 and 254 go head-to-head. I don't know who is better (all I have for 1986 is OPR numbers and god knows how accurate those are.)
Why couldn't they both come to IRIIIIIIII?!?!?!
(2015-Present)
Unread 29-08-2013, 10:15
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
I would have been happy if one of them went
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 29-08-2013, 11:17
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
254-1986-1806
The "We couldn't make it to IRI" Alliance.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 29-08-2013, 11:26
Racer26 Racer26 is offline
The trouble with threads like this is that there's 8-12 teams that are right at the top there, and they're pretty much interchangeable for the purpose of a discussion like this.
A dream team consists of 3 teams that have compatible 30 pt climbs, and at least 2 of them have dumps. Additionally 1 must have a 7 disc auto. Better if one of the others additionally has a W2W 5 disc.
254, 67, 1114 fits this bill nicely.
The lack of a 30 pt climb really hurts 2056 for being placed on one of these 'ideal' teams.
254 could easily be substituted for 1986. Their robots perform nearly identical functions in a nearly identical fashion.
67 could be swapped for 1334, again, similar functions.
There are a number of teams from which you can form these dream alliances. Any one of these dream alliances would be pretty much unstoppable.
Unread 29-08-2013, 14:44
Rynocorn's Avatar
Rynocorn Rynocorn is offline
Strategist and Designer
AKA: Ryan Jacobs
FRC #1466 (Webb Robotics)
Rynocorn is on a distinguished road
There are about 20 alliances that would all be almost equal but I would have to go with 254, 1806, 67 being the best.
The two full court shooters could empty all the discs with 254 cleaning up and possibly taking some discs from the opponents side of the court. After discs are gone 1806 and 67 climb and 254 climbs at the very end.
13 in auto- 78
45 in top goal- 135
3 climbs (30,30,20)- 80
6 discs dumped- 30
=323 buttt the whole time 254 can be scooping up the other teams misses, which always happens so the total will be higher.
Also, this team would be incredibly repeatable as each of the robots isn't doing anything hard at all but each a relatively easy task but working as a team.
That's my thought on the whole thing
My favorite parts: Surgical tubing, Grab catches, churro tubing, and waffle tread.
Unread 29-08-2013, 17:12
1986-1918-1114
Wait WHAAAAAAT?
1986- 5 Discs in auto (centerline)
30 Point Climb
1918- 5 Discs in auto
30 Point Climb
20 Point dump
1114/67/1334/etc- 3 Discs in auto
30 Point Climb
10 Point Dump
Really this alliance has no advantage over the others in this thread, but it's an option that is a little different than the others. It still maximizes the amount of points one can get, but in a different way by replacing the 7-3-3 auto combination with a 5-5-3 auto combination. Now, if 1918 could do a 7-disc auto, they'd be the only team in the world with a 7-disc auto and an outside-the-pyramid 30 point climb.
I would probably run 67 in this set, just for the fact that they, alone, can score the entire feeder station's worth of discs.
(2015-Present)
Unread 29-08-2013, 20:15
Mrcope9's Avatar
Mrcope9 Mrcope9 is offline
AKA: Matthew Cope
FRC #3991 (KnightVision)
Mrcope9 is a glorious beacon of lightMrcope9 is a glorious beacon of lightMrcope9 is a glorious beacon of lightMrcope9 is a glorious beacon of lightMrcope9 is a glorious beacon of light
Each alliance should have...
1 consistant full cout shooter- I give this one to 148. They had one if the most accurate full court shots this year. I think they probably scored more than 100 frisbee points in a single game a few times this year. Besides The Robowranglers, 67 and 469 both had quality FCS. But, it goes to 148.
1 reliable cycler. We saw in the championship that 3 cyclers was the best type of alliance. A cycling robot with a fast floor pickup makes a great addition. I would probably go with either 2056, 118, 3476 or 1477. All of these can score, but I give it to 2056.
1 fast climber with a solid shooter. I have to go with 254. They could climb to 30 in the time it took most to reach 10. 1986 and 1114 also had great climbs, but The Poofs get this one.
In total, 148 could hit at least 25 shots from full court + autonomous + a 50 pt. climb and dump. That's well over 120 pts, give or take. 2056 had a 7 disc auto + a deadly accurate shooter, and a 10 pt climb. Probably about another 100 pts right there. Then, 254 has its 7 disc auto + another quality shooter + a 10 second 30 pt. climb. I think this group can hit 300 pts.
Unread 29-08-2013, 21:18
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
One quick flaw: 148 can only climb to 20 and does not dump. If you want the FCS/50pt climb and dump, go for 67.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 29-08-2013, 22:02
Chris is me's Avatar
AKA: Pinecone
I love thinking about this kind of thing and I'll possibly come back later to contradict myself.
First things first, full court shooters aren't going to help here. There are a few (67, 148, 195, 2169, etc) that are accurate enough to be a part of this discussion, but with 45 + 6 discs, it's just too easy to get 11-12 cycles out of three good cyclers. Anyone who wants to contest this can go watch Einstein and IRI again. One could argue that an FCS will more efficiently feed a ground loader, but there aren't a ton of ground loaders that work as quickly as an optimized cycler even with a ton of discs on the ground.
Autonomous mode has to be covered. At least 13 discs for the alliance, which isn't hard to do. 15 discs is nice but I don't think it's absolutely necessary - I'll say it'll break a tie in this discussion but so many robots are good at covering the middle discs that it almost doesn't matter.
Climbing points are where the discussion gets interesting. Obviously an ideal alliance wants as many as possible - but the more climbers you have, the less end game cycling happens. There's also diminishing returns to a small extent on climbing, as only two robots need to dump. I think it's pretty reasonable to say the ideal alliance needs at least two thirty point climbers.
So let's see what robots we have to work with here. I'm assuming every robot is playing at their peak performance in season or IRI. I won't consider "a better driven version of Team XYZ" or anything like that though.
My first guess for an alliance would be 254, 1114, 67. 67 is *the* 50 point dump FCS - and they happen to be one of the most accurate and fastest FCSes in the world. A perfect fit for a floor loader like 254. 90 climb points, 30 pyramid points, all 45 white discs in the goal, and 13 discs in autonomous gets you 303 points. I won't really try and guess how many opponent discs they can go for without some very hard data on how effective these three teams are...
The other three-climber alliance that could possibly exist would be 1986, 1114, 1334. This alliance gives up full court shooting in exchange for quicker and more reliable cyclers. I don't think there's a doubt in anyone's mind that these three robots could each manage four cycles a match. 1986's floor pickup isn't stellar in teleop but it's good enough that they could probably manage to get a cycle of missed discs. Same point ceiling, different (probably safer) strategy. Plus this alliance has more of a "new school FRC" feel to it.
There are other non 30 point climbing bots that are so exceptionally good that they deserve consideration. 2056, 469, 1310, and 118 are all absolutely excellent robots at their peak and I believe all of them have had 90+ point contributions in a match before. The only way these teams could keep up is if they found 20 points (opponent missed discs, etc) that 254 / 1986 couldn't find. That said, if anyone could do that, it'd be 2056 and 469. That would be an interesting alliance, 1114 / 2056 / 1334... now where have I seen that before...
Unread 29-08-2013, 23:56
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
I find it interesting that a majority of people seem to value the two centerline disks in auto over an overall better fit for strategy.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 30-08-2013, 00:02
See, I disagree. I think any of these combinations of teams could score every disc in the feeder station. Or at least most of these combos.
Any combo with 67 involved only needs someone to pick up a few discs off the floor to score every disc, technically.
I think the 67-254-1114 alliance could EASILY score every disc in the feeder station.
Additionally, I think the 1986-1918-67 could do it as well.
Really it comes down to scoring ALL of your discs, maximizing auto points, and maximizing climb points.
Reliability might come into play, as any alliance with 67 fcs'ing is inherently unreliable due to the ease at which one can block 67. But there are other ways to do this. Cycling can likely score all these discs as well.
In summary, I think most of these combos definitely consider alliance composition and strategy.
(2015-Present)
