Go to Post For those who don't have snow in the forecast - i.e., not New England - just send me your shipping address and I'll FedEx some snow to you right away. We have extra. :p - DonRotolo [more]
Unread 01-09-2013, 01:43
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Re: Drivers Control
Originally Posted by raphaelchang View Post
Starting in 2013, 846 has a been using a steering wheel for turning and a joystick for throttle. Having the turn and throttle components on separate controls allows us to drive straight and turn in place more easily, and it also allows better control of arc turning (turning while driving forwards/backwards).
We found this as the optimal driving scheme after experimenting with several other setups as well:
2011-2012 - Single joystick for forward and turn, forward and back motion for throttle, joystick twist for turn. This made arc turning difficult because both motions were controlled with one hand. Turning in general was also difficult because the twist was more sensitive and turning with the wrist was more difficult to control precisely.
Off-season - We also tried two other setups during off-season, tank drive and vector drive. Tank drive used two joysticks, one to control the left side and one to control the right side. This made the driving feel more natural, but it also made precise control difficult. Driving straight was difficult and precise turning speed was hard to control. Vector drive used the angle of the joystick to specify the direction of the robot and the magnitude to control the speed. The robot would turn automatically to face the angle pointed by the joystick and move forward at that speed. Although this field-centric setup made it easier to go the direction we wanted, it was difficult to control for tight manipulations.
Any chance you could post the model of steering wheel?
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 01-09-2013, 02:01
raphaelchang's Avatar
raphaelchang raphaelchang is offline
Funky Monkey
AKA: Raphael Chang
FRC #0846 (The Funky Monkeys)
raphaelchang will become famous soon enoughraphaelchang will become famous soon enough
Re: Drivers Control
We use a Ferrari GT Racing Wheel for our steering wheel. It can be found here: http://www.amazon.com/gp/product/B000U1MU2K/sr=1-1/qid=1357360819/ref=olp_product_details?ie=UTF8&me=&qid=1357360819 &seller=&sr=1-1
Unread 01-09-2013, 20:18
Gabrielle62 Gabrielle62 is offline
FRC #2994 (The ASTECHZ)
Gabrielle62 is an unknown quantity at this point
Re: Drivers Control
For the past few year 2994 has used 1 or 2 logitech joysticks depending on if the driver preferred tank or arcade drive and then a logitech gamepad for everything else (this year the mini joysticks for rotating the arm and the buttons for shooting, and last year the same buttons for shooting).
Unread 01-09-2013, 20:39
robowrestler's Avatar
robowrestler robowrestler is offline
AKA: Collin
FRC #3015 (ranger robotics)
robowrestler is an unknown quantity at this point
Re: Drivers Control
2011- cyborgx joystick arcade drive style on a west coast drive
2010/2012- cyborgx joystick on a mechanum drive also arcade style
2013- xbox controller with an arcade style drive on the a modified kit bot chassis
my favorite was the xbox controller it was a lot more comfortable to drive with and the co-driver also had one controlling the shooter
2016 Pittsburg Regional Chairmans Award Winners
2016 Pittsburg Regional Finalists with 1023 and 4050
2015 Newton Division Finalists with 195,1756,4522
2015 Finger Lakes Regional Winners with 4039and 378
2015 Finger Lakes Regional Engineering Inspirational Award Winners
2014 Finger Lakes Regional Finalists with 340 and 3044
2013 VA Regional Finalists with 2363 and 2053
2012 Finger Lakes Regional Finalists with 340, 4124 and 3044
2012 Buckeye Regional Winners with 340 and 1507
"Kickin Bot Since 2009"
Unread 01-09-2013, 23:00
ErvinI ErvinI is offline
AKA: Ervin Ibadula
FRC #0865 (Warp7)
ErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really nice
Re: Drivers Control
From what I know, which may not be correct outside of 2012 and 2013:
Main Driver:
  • 2010: One Joystick. Either Attack 3 or Attack 3D. Arcade Drive variant where rotation was done through two buttons on top of the joystick (our programmer was new that year ).
  • 2011: Tank Drive with two Attack 3 Joysticks.
  • 2012: Tank Drive with two Attack 3 Joysticks.
  • 2013: Tank Drive with two Attack 3 Joysticks (I see a pattern here...)
Driver preference tends to be key. Our drivers have often times preferred tank drive over Arcade/ Kaj Drive because they like the ability to reduce the power going to one wheel independently from the other wheel. For some drivers this is difficult to master, however it works great for precision steering if trained properly.
Unread 01-09-2013, 23:14
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
Re: Drivers Control
2011: We used 1 Logitech controller for arcade drive, and a custom board for positioning the arm. It had a "Mini me" version of our arm with potentiometers and correct arm segment lengths that we used for custom positioning. It also had buttons in a layout for the drivers to press, along with sweep and station, and "Barf and flip", which was used for clearing the tubes.
2012: 1 xbox controller for octocanum control. Also controlled bride manipulator. 1 logitech for turret, intake, and firing control.
2013: 1 flight controller, 1 logitech. The flight controller had a constant rate throttle, and an arcade joystick for turning. Also controlled hanging. Logitech controlled all disk handling and lateral aiming, in addition to firing.
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
Unread 01-09-2013, 23:50
alex.lew alex.lew is offline
college student
FRC #1912 (Team Combustion), FRC #0558 (Elm City Robo Squad)
alex.lew will become famous soon enoughalex.lew will become famous soon enough
Re: Drivers Control
We have used a Logitech joystick for arcade drive for the past two years, our driver preferred that over 2 joysticks for tank. We use the eStop Robotics Custom Control Interface (CCI) as a button board. It opens as another joystick in code and is very easy to set up and maintain, total cost of only $40. You can add pretty much any button / potentiometer / switch you want. We had a "big red FIRE button" to control our shooter and was directly cited in our Quality Award at Razorback Regional.
Plus it's really fun to show kids at demos
Unread 02-09-2013, 01:40
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Drivers Control
This year, we used the circuit board from a Logitech gamepad to run a modified pistol-grip RC car controller for the driver and a custom control box for the operator.
This system worked very well for letting the drivers control the robot, but we had some trouble with the gamepad electronics, since they're really designed to control a gamepad and nothing else. Next year, we'll probably use the pistol grip controller again, but with something like the eStop Custom Control Interface instead.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 02-09-2013, 03:46
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: Drivers Control
From what I can remember from my time on my team, we've used these control setups for driving our robots...
  • 2006: Tank Drive - 2 Joysticks (the old, black Flight Stick controllers) for driving, plus one custom 4-button control box for switching between collection/shooting modes.
  • 2007-2008: Tank Drive - 2 FS Joysticks for driving, plus 2 additional joysticks for other robot functions.
  • 2009-2010: Tank Drive - 2 Logitech Attack 3 Joysticks for driving,
  • 2011: Tank Drive - 1 Logitech (PS3) Gamepad for driving, modified NES controller for the robots arm (Robot was reprogrammed after the season to require only the one Logitech Gamepad to control all functions, minus gear shifting, which was disabled).
  • 2012-2013: Tank Drive - 1 Logitech (PS3) Gamepad for driving and other functions, no other controllers.
Having been a robot driver from 2006-2008, and, as a mentor, having also been able to occasionally drive every robot since then, I must say I'm still partial to older dual-joystick controls. You just don't seem to get the same resolution in the controls with the newer gamepads like you did with those old Flight Sticks. But that's my 2 cents at least.
Unread 02-09-2013, 21:49
Oak1477 Oak1477 is offline
FRC #1477
Oak1477 is an unknown quantity at this point
Re: Drivers Control
This year our team used a modified rc controller for the driving aspect and for the shooting we used an xbox 360 controller.
The rc remote was Spektrum dx2e that we gutted (except for the power switch and the potentiometers) and put an Arduino uno in that we porgrammed to act as a logitech joystick.
Our team lets the drivers choose the controller they want to use. We believe if the driver is comfortable with the controller they will perform better.
Unread 03-09-2013, 17:13
Racer26 Racer26 is offline
Re: Drivers Control
Us FRC old-timers remember the old black Flightsticks (with just a trigger and top button) that were replaced in the KOP in 2004 by the crappy beige joysticks in the kit from 2004-2008.
MANY teams continued using the far superior black Flightsticks until they were completely dead, especially for controlling the drivebase with. Some teams modified them to add extra buttons, or different handles. It was an interesting time.
In 2009, most teams used the Logitech joysticks we know and love today.
