Go to Post I always wondered what would happen if two robots mated. - Greg Needel [more]
Unread 04-02-2003, 15:57
Jeremy J's Avatar
Jeremy J Jeremy J is offline
#0871 (West Islip Robotechs)
Jeremy J is an unknown quantity at this point
Send a message via ICQ to Jeremy J Send a message via AIM to Jeremy J Send a message via Yahoo to Jeremy J
Wierd basic init
I'm trying to get a gyro sensor to output to a motor controlled by a joystick, by setting the joystick port to the sensor. I'm getting a basic init error when I try to do this. Anybody got any clues why?
"...at about this time, somebody will be telling you to get on the plane, on the plane, on the plane. I say **** you, I'm getting IN the plane!" - George Carlin
-2002 Rookie All-Star
-2003 LI Regional 2nd place
Unread 04-02-2003, 16:58
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Basic Inits usually occur when your constants (c_p1_x, c_sensor1, etc) don't match your SERIN. If you drop your code in RoboEmu, it can usually detect these errors for you. Otherwise, feel free to post code here and I'd be happy to take a look at it.
--Rob
Unread 05-02-2003, 20:59
Iain Iain is offline
Iain is an unknown quantity at this point
Yeah, we've had two instances where our other programmer changed the serin command without remembering to change the initialization constants to match, and couldn't figure out what was causing the error.
He, unlike me, actually knows BASIC, but I, unlike him, have studied the specifics of PBASIC and the robot controller fairly closely, so we have to work together on this stuff.
Unread 05-02-2003, 22:08
wwrye wwrye is offline
#0057 (Leopards)
wwrye is an unknown quantity at this point
Exclamation serin
As long as no changes have been made to the 'PBASIC - MASTER uP INITIALIZATION ROUTINE, the section right before the main do loop starts, then you have a problem with your serin command and or your 'DEFINE CONSTANTS FOR INITIALIZATION section. Look at those 2 sections and assure that for every constant set to 1, there is a corresponding variable in the correct order in the serin command.
Unread 06-02-2003, 01:35
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
I've found if I leave debug statements in my code, upload the program, and unhook the serial cable it gives me a Basic Init Error. This never happened in previous years though.
Check your program for any debug statements and try commenting them out.
Unread 06-02-2003, 11:42
Ryan Meador Ryan Meador is offline
Team Role: Electrical
Ryan Meador will become famous soon enough
The new PBASIC 2.5 allows for two-way debugging... i.e. the computer can send stuff back to the stamp.
-Ryan
"You're not a real programmer until you end all your sentences with semicolons;"
Impending BASIC Stamp Editor Beta 2 release Greg Ross Programming 9 19-09-2003 06:05
Basic Run Error BBFIRSTCHICK Programming 10 02-04-2003 22:43
Manchester Rgnl. ETREMELY basic scouting DB Rick Regional Competitions 9 24-02-2003 19:07
no basic stamp found! DLyons Programming 7 23-12-2002 22:17
Basic Init Error yan184 Programming 5 14-12-2002 13:10
