Go to Post You don't have to beat stronger teams to get better... to get better is to be forced to push the envelope against stronger teams. - Shankar M [more]
Unread 03-09-2013, 14:15
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
pic: FRC488 - Fall Project, Rev. A
Unread 03-09-2013, 14:17
Madison's Avatar
FRC #0488 (Xbot)
Re: pic: FRC488 - Fall Project, Rev. A
Now that I've got a bit more time, I can write a bit more about the changes I made between the first iteration of this design and this one. Most of the changes were directly influenced by feedback I received in the other thread. I appreciate everyone's feedback and questions.
Wheel Modules:
  • Added vertical flanges along the front and back edge to tie into the
    belly pan.
  • Replaced 3/8" hex standoffs with 3/8" round spacers and 10-32 bolts inside. I stayed with 3/8" here rather than 1/2" since the VexPro gears' 1/2" hex bore can rotate freely about a 3/8" spacer and probably won't do so around a 1/2" spacer. We could open the bore on the gears up on a drill press since concentricity of that hole is not a concern, but I am not sure the switch to a 1/2" spacer is worth the effort. It's possible to change my mind.
  • Haven't yet decided between a long spacer or a shaft collar to locate the idler gears axially.
  • Swapped the 35 tooth idler gears for 48 tooth gears; this allowed me to move the idlers upward some, creating clearance below to extend the belly pan to the outer face and adding torsional stiffness to the module via the now offset wheel / idler spacers.
  • Eliminated the hole-slot pattern for a simpler hole pattern. The hole on top will get shifted toward the outer edge; I see now that I moved them the wrong way yesterday.
  • Reworked ball shifter mount and added captive nuts to the inside face of the module to accept the transmission bracket. The transmission can couple to any of the three inner wheels.
Belly Pan:
  • Extended the belly pan to outer face of wheel modules and added short flanges to couple the outer module face to the belly pan with rivets.
  • Removed taper from front and rear flanges.
  • Our electrical system layout is not in my sphere of influence, so I will need to provide several mounting options and they will give me a board of their own design to couple to the belly pan.
  • Added battery box. I will redesign this tonight; I am not happy with it and it can be one part instead of two.
--Madison--
...down at the Ozdust!
Unread 03-09-2013, 15:57
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Hi Madison,
The battery box can also hold the breaker and provide a base for easy access to the breaker. It can also hold a data access port for connection to the router. How many times have you seen teams struggled to gain access to the router data ports? Maybe even hold the sidecar for easy access.
Don't forget the mounting holes for the manipulator and the bumpers brackets.
Make sure there is adequate bend relief where the angled belly pan and the wheel housing meets. The parts will align easier if tolerance on the tab is loose.
Using pins to hold the wheel assemblies make it easy to drop a wheel out of the assembly. Using dowel pins also helps align the transmission gear to the drive assembly. Bring the gear closer to the transmission bearing keeping the distance to a minimum.
I feel the corners need some triangular gussets to reinforce the corners should you get a big hit.
Whats the drop on the wheels? Driving more than six wheels means you get a lot of wheel scrub. The outer wheels will scrub down to nothing if there is a lot of turning and the drop is minimal.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 03-09-2013, 16:32
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Is this a 2012 or 2013 rules drivebase?
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 03-09-2013, 16:49
Madison's Avatar
FRC #0488 (Xbot)
2013. It's just about 28" x 28".
--Madison--
Unread 03-09-2013, 21:48
OWilliamson's Avatar
OWilliamson OWilliamson is offline
FRC #2594 (NASKCO)
OWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of light
I'm not sure if you had considered this, but cutting out part of the bellypan where the gearboxes will be above can make maintenance a lot easier. We didn't do that this year and it was a nightmare trying to repair our gearbox before eliminations.
2015: Utah Regional - Quarter-Finalists (3374 & 4158)
2014: Utah Regional - Semi-Finalists (1619 & 399)
2013: Utah Regional - Quarter-Finalists (1332 & 3562)
2012: Utah Regional
Unread 03-09-2013, 21:59
dodar's Avatar
This times a thousand. We built a bellypan and then realized we needed to and cut it out after the fact, which didnt look pretty, but it was glorious. That and it saved close to a pound.
Unread 03-09-2013, 22:55
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
Maybe you should think about having the belly pan Plexiglas or clear plastic. It saves weight and you could put some cool LEDs. Also, you could make it removable to put electronics or make it easily accessible if you need to fix something
Unread 03-09-2013, 23:06
dodar's Avatar
No, you want the metal for rigidity. Plus, CNCing out all the material into that pattern saves quite a bit of weight already.
Unread 03-09-2013, 23:15
Slave to the bot
AKA: Chad Krause
Team Role: Driver
You are right, maybe it should be just a middle piece cut out. The reason being that this metal underbody is just added weight that can and should be removed
Unread 03-09-2013, 23:33
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I have to say, this is a really beautiful design. It looks just like 971, but with gears instead of belts. I'm a huge fan.
Just a few questions, perhaps they've been addressed elsewhere. Any reason you've chose 10 wheels? I don't see any advantage for 10 over 6, and having more wheels carries cost and weight (not to mention potential turning) disadvantages. Also, I'd assume these parts are being laser cut? Waterjetting or turret punching those parts would take a lot of sponsor time.
-Plutarch
Unread 03-09-2013, 23:35
I'm guessing because designing for ten allows for configurations of 6 and 8. Correct me if I'm wrong please.
Unread 04-09-2013, 00:19
Billfred's Avatar
Billfred Billfred is offline
If you're still going to power the corner wheels, a gear has to occupy that space anyway to act as an idler. Why not run 10 at that point?
Unread 04-09-2013, 01:20
Chris is me's Avatar
AKA: Pinecone
Done properly, the weight gains are marginal and the added strength and rigidity are quite useful. In a sheet metal drive like this, the lightened metal belly pan is what holds the entire design together (literally and figuratively).
"metal is weight and weight is bad" isn't by any means necessarily true.
EricH EricH is online now
Not really. You need something there, unless you like frames being non-rectangular parallelograms or other interesting shapes. We're talking 0.090 sheet metal here, with a weight reduction pattern--can't get much thinner and lighter than that without needing some extra support. If that bellypan is more than 2 lb, I'd be shocked; I wouldn't be surprised if it was closer to 1 lb or under. Removing more weight won't exactly help in this situation.
