Go to Post To have respect for the process you are in right now, respect the knowledge around you by using it to your full advantage. - Scott Ritchie [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 02-09-2013, 18:16
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
Custom wheel making
Has any team here made custom wheels here. If so what was your process. How much did it cost? and did it work they well?
Unread 02-09-2013, 18:44
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Custom wheel making
Yes. CNC Milling. $1.69/lb. Yes.
Unread 02-09-2013, 22:04
safiq10's Avatar
what was this wheel made out of and do you have a picture of it? Thank you for responding.
Unread 02-09-2013, 23:14
The best I have is this picture of our whole robot. The wheel was made out of 6061-T6 aluminum round bar. It took about 20 minutes each to machine on a vertical machining center. The majority of the time was cutting the groove for the tread and corner rounding the edges. I could probably cut down the cycle time now that I've learned a bit more about feedrates and material removal rates.
If you search the CD media section, there are several examples of custom made wheels.
Wheels can even be made on a manual mill and/or lathe if you don't have access to a CNC, and if you have enough patience and time.
Unread 02-09-2013, 23:19
Here's two better pictures.
http://i.imgur.com/btUmTzW.jpg
http://i.imgur.com/ZUqlDUP.jpg
Unread 02-09-2013, 23:27
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Originally Posted by Akash Rastogi View Post
Dude. That is one gnarly gearbox. I love the ano, HSM pocketing, and the ratchet. Was it for a lock for a 30 point climb?
-Plutarch
Unread 03-09-2013, 01:38
saikiranra's Avatar
saikiranra saikiranra is offline
UCI
AKA: Saikiran Ramanan
FRC #3476 (Code Orange)
saikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond repute
Thank you!
Yes, the ratchet is attached to a spindle, which can be engaged by actuating a pancake piston. It can be used for a 30 pt climb, if anyone decides to actually design it.
2014 - Current: Team 3476 Electronics, Programming, and Scouting Mentor
2011 - 2014: Team 696 Student and Drive Coach
Unread 03-09-2013, 22:46
peirvine's Avatar
peirvine peirvine is offline
GOFIRST Director of Engineering
AKA: Peter Irvine
FRC #2175 (Fighting Calculators and Ri3D 'Snow Problem)
peirvine is an unknown quantity at this point
Yes. We had a friend at Stratasys 3D Print 2 different versions of them (see picture below). The white wheels were Gen1 and they were made from abs m30, we ran into the problem of hubs getting stripped of their hex shape, so we replaced them with the black ones which were made from Ultem (which were about twice as strong) and they seem to be working just fine. For us the wheels were free, but MSRP we have heard (from different people) that they range from about $150/wheel to about $300.
2014 Northern Lights Regional-Winners (Thanks 359 and 2502)-Industrial Safety Award-Excellence in Engineering-North Star Regional-Industrial Safety-Creativity-WFFA (my dad!)-Semifinalists (Thanks 967 and 4607 (again!))
- Division Finalists (Thanks 2169 and 3284)
2013 Northern Lights Regional - Quarterfinalists, Entrepreneurship Award - Dean's List Semi-Finalist - North Star Regional - Winners (Thanks 967 and 4607), Team Spirit Award - 2013 MSHSL State Tournament - Winners (Thanks 2052 and 4607) - IRI
2012 Lake Superior Regional - Quarterfinalists, Coopertition Award - North Star Regional - Quarterfinalists, Creativity Award
-North Star Regional - WFFA Will Preska, Semifinalists
Unread 04-09-2013, 00:40
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Wow... And I thought AM wheels were expensive. That seems like some really nice stuff. Any reason why the 3D printed one is better then say an regular Alum one (besides the fact it was free ).
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 04-09-2013, 00:49
Aren Siekmeier's Avatar
on walkabout
We didn't have the CNC machine time and Stratasys can print oodles of these for machine tests and demos. We were looking for a one piece wheel that would have been expensive to purchase otherwise.
Unread 04-09-2013, 10:05
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
How did the cost break down for the 3D printed wheels? Was it mostly materials or simply having them 3D printed? Do you know if a team has their own 3D printer about how much it would cost to print each wheel?
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 04-09-2013, 11:13
peirvine's Avatar
AKA: Peter Irvine
I believe that with our final set of wheels, the consumer grade couldn't handle the material or the size of the job. It would also take a VERY long time. The shop that we work out of has a 3D printer and even printing wheel spacers takes a good deal of time.
Unread 04-09-2013, 11:17
AdamHeard's Avatar
Lead Mentor
We're a team that used to make custom wheels every season, and we likely won't ever again.
Just too many solid COTS options, unless you have every part of your robot perfect, it's really a wasted resource to make custom wheels.
Sure are cool though.
Unread 04-09-2013, 14:33
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Below is a link to some pics showing the evolution of the design we used from 2007-2010. We stopped doing it when the AM performance wheels became cheap enough and available in the right configuration so that we had no real gain from making our own.
The raw material cost on these was less that $5/wheel but not having to worry about the resources to make them is worth paying for wheels to us.
This is the driven version. We also made a live axle version.
http://www.chiefdelphi.com/media/photos/31102
http://www.chiefdelphi.com/media/photos/31104
http://www.chiefdelphi.com/media/photos/31105
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 04-09-2013, 15:07
Brandon Holley's Avatar
Cannot agree more with this entire post.
We made custom wheels for a long time, and when we started looking at COTS options and the time difference between implementing them- it was a no brainer to go COTS.
They make for a fun project, and there are a ton of cool things you can do with them in terms of making them (machining, molding, printing, etc). For us, the effort is just better spent in other places.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
