Go to Post The most amazing and inspiring character I've met in FIRST, Wayne [Cokeley] has definately shown me the character of a true leader. - Bharat Nain [more]
Unread 04-09-2013, 10:39
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
Re: Apple Computer and Labview
Originally Posted by Bpk9p4 View Post
it sounds like my team will need to keep using parallels. Any suggestions on a good way to get windows to students. buying a version of windows for everyone wanting to learn LabView on the team is not in are budget due to are software team growing. We are debating moving to java for this reason. We really do not want to though due to are great experiences with Labview
Giving windows to every studio IS very expensive. We just switched to Java this fall for the same reason (not that we have many Macs but that Java is not platform dependent). It's not a bad choice because we actually liked developing in Java; it's a good start for programming in the industry.
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 04-09-2013, 15:26
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant future
Do you have any good source to learn more about FIRST and java. How hard was the transition?
Unread 04-09-2013, 20:04
I don't know details, but MS donates Win7 licenses to FIRST. I'm not sure if they are only for the new classmates or can be used on other computers.
https://www.microsoft.com/about/corp...ats-available/
Above URL also seems to be an option. At the bottom it seems that you may simply need to ask.
Greg McKaskle
Unread 04-09-2013, 21:10
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
This is a fairly good resource that provides overviews from various programming concepts both basic and advanced. Also, the videos on Brad Miller's YouTube channel are awesome for actually learning how to code a robot fairly well, no previous Java experience required. You will notice that there are 2 sets of videos, one of which involves regular Java programming and the other involves java programming with robotbuilder. Robotbuilder is a tool that allows you to put in information about your robot and what you want it to do, and it will generate a good chunk of your code for you based on the information. It makes it so that you do not have to actually type much actual code, just plug in a few numbers into the interface. It can be a bit limiting if you want to do some fancier stuff, but you can always just bypass the robotbuilder and code that part of the robot the old fashioned way. I am a new coder, so I don't have any experience with either method, but from what I know about robotbuilder I would definitely encourage a team just starting with Java to use it.
