Go to Post Our team calls me "John Regular Neun," because John V-Neun is so spectacular! - John Neun [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 09-04-2013, 03:35 PM
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: Custom wheel making
Originally Posted by Brandon Holley View Post
Cannot agree more with this entire post.
We made custom wheels for a long time, and when we started looking at COTS options and the time difference between implementing them- it was a no brainer to go COTS.
They make for a fun project, and there are a ton of cool things you can do with them in terms of making them (machining, molding, printing, etc). For us, the effort is just better spent in other places.
-Brando
I agree entirely as well, but if you have the resources readily available, it can be cheaper to make your own wheels.
In 2008, 2079 needed leather treaded wheels (torque miscalculation required that our swerve drive have very little friction on the wheels). We found a lot of suitable off-the-shelf wheels that were very expensive compared to the cost of raw material, and relatively minimal machine time to create a simple wheel. We were able to create some very cheap custom wheels for our intake in 2009.
I suppose it does depend on what you use the wheels for, which ones are available for purchase that suit your needs, and how you are going to fabricate them.
Unread 09-04-2013, 04:10 PM
AdamHeard's Avatar
Lead Mentor
I think a great model to apply in situations is WW2056D (What would 2056 do).
Across the board on their designs, they seem to much prefer to buy existing solutions from a variety of COTS sources even though they do have fabrication options.
This lets them finish sooner, and with less work.
We're trying to apply the WW2056D model versus the machine it all because you are capable of machining it all model.
Unread 09-04-2013, 07:58 PM
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We're a team that used to make custom wheels every season, and we likely won't ever again.
Just too many solid COTS options, unless you have every part of your robot perfect, it's really a wasted resource to make custom wheels.
Sure are cool though.
We started with this idea, but found that our COTS wheels (Colsons) were too small, and no COTS wheels would fit our design after the face. So, we went custom.
By the time we manually machined, knurled, broached, and pressed hubs on the Colsons, we just about could have made our own wheels to the perfect size. And, we can do it in-house, and while we can still get aluminum for $1.69/lb, we might as well.
If there was a COTS wheel that was the same size, weight, and bore that we'd make anyway, I wouldn't bother making them. But I've yet to see something good with a 7/16" hex bore.
I agree though, that you should definitely attempt to buy over building, if the off the shelf options fit your needs. You're not just buying wheels, you're buying time.
Unread 09-04-2013, 08:43 PM
Holtzman's Avatar
Holtzman Holtzman is offline
Sometimes...
AKA: Tyler Holtzman
FRC #2056 (OP Robotics)
Holtzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond repute
Send a message via MSN to Holtzman
For us, custom wheels are filed firmly in the ANGTFT category.
"making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." - Charles Mingus
Unread 09-04-2013, 09:00 PM
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Are team custom made these wheels in 07.
http://www.chiefdelphi.com/media/photos/20329
They are made from aluminium tubes with a aluminium disc welded in the centre. A live axle hub is welded to the disc. It was then sand blasted to give it a nice finish. The tread is riveted to the tube. In this case time was the majority of the cost.
2016: FRC 865 Mentor
