Go to Post Now that football is over... ARE YOU READY FOR SOME ROBOTS?!?! - KelliV [more]
Unread 04-09-2013, 22:44
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Re: Custom Robot Controller
That sounds like Network Tables to me :) Check out the information here. You would get the input from your custom controller in the desktop side and send it to the robot side. I think most people use a Teensy USB development board or a USB IFI Chicklet in the construction of their custom controllers (verify this?). I'm pretty sure this is almost but not quite the answer to your question. (You might want it to literally show up as a joystick, plug and play, so you could simply use the Joystick classes in the WPI library. If so, I'm also looking for a way to do this :P ).
Unread 05-09-2013, 23:57
The Numenorean The Numenorean is offline
FRC #2984 (The Vikings)
The Numenorean is an unknown quantity at this point
You are right about that not being quite what I want, but I have a feeling it is very complex, will pass it on if I find a way though
Thanks for the tip about NetworkTables though, they may be just good enough to work, am trying now
Unread 15-09-2013, 10:11
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
another possiility, look at Virtual Joystick. Defines a virtual joystick on the driver station that you can manipulate from other programs running on the driver station. http://vjoystick.sourceforge.net/site/
not as easy as network tables, though....
