Go to Post Its great for us as mentors to see students teaching other students and a robot being built from scratch without us. Maybe someday they won't need us at all!!! - DR3381 [more]
Unread 04-02-2003, 18:26
Dick Linn's Avatar
no team (Synergy)
gear lash
This may or may not be your problem. If you don't have the spacer tubes in the transmission really snug, when you shift from forward to reverse you will be slamming the gears forward or back on the shaft until they stop. The Bellville spring washers were intended to be used to add a certain amount of preload. On another thread it was stated that the thrust generated by these helical gears parallel to the shaft was about 190 pounds if I recall correctly. If your spacers are sloppy, this will slam things around and could tear up the gearbox. I'm still trying to find out what the correct spacing is to use the spring washers. If too tight, they cause quite a bit of drag.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
Disabling drill transmission clutch Charlie B Motors 2 31-01-2003 10:02
BOSCH Drill Transmission Assembly archiver 2001 2 23-06-2002 22:08
Mating gear with drill transmission thedillybar Technical Discussion 0 13-02-2002 21:08
