Change Network name of the d-link?
Our team is wanting to use our Ultimate Ascent robot and a test robot to train new drivers. When we use either one by itself, they work just fine. We aren't able to use both of them at the same time, because the IP addresses conflict. How can we change one of the d-links so that both of the robots can be controlled at the same time?
Re: Change Network name of the d-link?
Give your second robot a different team number, so they both don't think that they are 3160.
Thanks for the reply. I will try it out next thursday when the team meets again.
So, after reimaging the crio, we've run into a problem changing the d-link settings. The manual tells us to type the IP address into the address bar after we've set the laptop IP address to the proper number, and the browser fails to bring us to the page we need.
Have you tried the bridge configuration utility?
What he said.
Here's the tool: 2013 FRC Bridge Configuration Utility The most likely reason you can't reach the DLink webpage is that your laptop IP is incompatible with how the DLink IP/netmask is currently set. The laptop IP has to change several times during the DLink setup. The Utility takes care of all that by automatically changing the IPs for you. The Utility includes directions if you have to reset the DLink. Last edited by Mark McLeod : 06-09-2013 at 09:34. |
#7
Alright. Thanks a lot for the replies, hopefully it can get done next meeting.
