Go to Post There's a fine line between idolizing someone and stalking! - Jay H 237 [more]
Unread 08-09-2013, 00:25
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Powering 2 cameras
I know there are teams that have used more than one camera, but how do you power them if theres only one 5v port on the PD board?
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 08-09-2013, 11:20
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Powering 2 cameras
You can get 5v from the digital sidecar.
I usually power a camera from the DSC anyway since it's easier for wiring, since I have a lot of wire going to the DSC and it makes the routing easier.
Kettering Motorsports
Unread 08-09-2013, 11:37
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Here is the response from our electrical and command and control mentor:
A couple of years ago we did run two cameras on our robot. By wiring the cameras in parallel both get 5 volts and the current available on that rail (3 amps) is distributed between the two branches of the circuit. Remember in a series circuit current is the constant and voltage changes, in parallel voltage is constant and current changes.
Example:
C = Camera
5V ------- C -------- C ------- GND Series
          5V
     C           C       Parallel
     |___________|
          GND
Last edited by protoserge : 08-09-2013 at 22:23. Reason: Had to get to a computer to fix this more efficiently...
Unread 08-09-2013, 11:44
Tungrus Tungrus is offline
Tungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the rough
You may want to check the rules for connecting two devices in parallel to one power terminal.
Unread 08-09-2013, 11:47
apalrd's Avatar
More Torque!
VRC #3333
It's trivial to splice downstream somewhere. This specific rule is because the connector is only rated for one wire, not for any other electrical reason.
Unread 08-09-2013, 15:52
AKA: Spencer Lanman
so safest route is one camera on the DSC and one on the PD board?
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 08-09-2013, 20:53
apalrd's Avatar
More Torque!
VRC #3333
Neither one is 'safer'. Both places supply 5v power needed for cameras, either will work for either camera. You can also connect both to one of them.
Unread 08-09-2013, 21:51
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
We always used the standard power converter from AndyMark.
Unread 09-09-2013, 09:29
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
We ran two cameras off the PD board in 2012. No issues with power or rules. You need to watch the data rate through the wireless connection to the driver station though.
