Go to Post Now that football is over... ARE YOU READY FOR SOME ROBOTS?!?! - KelliV [more]
Unread 08-09-2013, 20:17
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: Creating the perfect robot
Originally Posted by bobby5150 View Post
Ok, I understand the design, but how in the world does it fit in the 54" cylinder? I know it's in any orientation, but its still the 54" diameter x 84" length cylinder, and I just don't know how you could build a platform that would hold 2 other bots. The idea would also make me nervous, as if you fall, you're taking down 2 other bots that may have never even thought to design for taking a fall like that. An alliance would be destroyed. Not to mention packaging all the other mechanisms would likely be a nightmare.
Nonetheless, it would be awesome if someone were to pull it off. Totally would be THE bot of the year. It'd be sick.
The platform idea is near impossible, but if you instead had two bars that stuck outside your bumper perimeter 30in off the ground for the other two robots to hang on (would require your partners to adjust their hangers) its feasible and I'm sure you could throw a very simple shooter that you could use in auto as well as make a few cycles before climbing for 30 with your partners.
1058 PVC Pirates 2016 - xxxx
