Go to Post This is a very cool robot. It doesn't look like a launcher... it looks like a lifter driving backwards. Then whammo! The ball is flying through the air. - dtengineering [more]
  #61   Spotlight this post!
Unread 08-09-2013, 22:41
BobbyVanNess's Avatar
BobbyVanNess BobbyVanNess is offline
AKA: Bobby Van Ness
FRC #0020 (The Rocketeers)
BobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of light
Re: Creating the perfect robot
Originally Posted by Thunder910 View Post
So a 6 CIM PTO 2170-style climb with two bars made for hanging somehow. That better be a stable climb. And then you're gonna put a shooter on it too?
Jeez.
Kevin, I think it would be a corner climber if it was possible at all. Think about it, as BrendanB said, 2 bars that the other bots use their 10pt climbs on, then it climbs smoothly to the top with 6 CIMs.
It could probably be done, although I'm still fairly skeptical. Also, maybe it's a good thing there weren't any teams that lifted other bots this year, or else GEICO would probably start offering robot insurance.
2016 TVR Finalists, FLR Champions, Carver Sub-Division
2015 TVR Finalists, Carson Sub-Division Champions, IRI
2014 TVR Champions, FLR Champions, Archimedes Division, IRI
2013 WPI Regional Finalist, Connecticut Regional Champion, Archimedes Division, IRI
2013 Championship and IRI Talent Show winner
2013 - 2014 Driver: 82-43
Lead Strategy Mentor: 32-15
  #62   Spotlight this post!
Unread 09-09-2013, 10:22
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Do keep in mind that for the other robots' climbs to count, those robots have to contact the pyramid at each level in sequential order.
  #63   Spotlight this post!
Unread 09-09-2013, 11:26
Professional Stat Padder
So basically this design would have to be engineered to an extremely precise degree with a ton of power and a ton of foresight. I also don't see the team that accomplishes this putting a shooter on the robot- but if they did, I don't see them making any cycles, just three shots in auto.
It would still be an amazing bot to have on an alliance even without that, it would just have to rely on it's partners for it's disc score. And it's climb would have to be quite fast, otherwise you'd be losing out on a lot of disc points (i.e. if the climb takes 40 seconds, then all three bots are out of commission for 40 seconds- if you were against HOT, they could score all the discs in the feeder station during that time).
What if instead of carrying all three other bots up, it lowered down a bar to the 10 pt level from the 20 or 30 point level that it could retract to carry bots up the tower? That could work. It still faces the power issues, but it allows for more time to be spent on disc scoring.
In reality I think any of these designs are implausible, and we should just settle for a combo of 469 and 67 being the best robot this year is capable of.
(2015-Present)
  #64   Spotlight this post!
Unread 09-09-2013, 12:43
foote stepped in
AKA: E. Foote
FRC #0868
Just gently bump them along each rung during the lift.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
  #65   Spotlight this post!
Unread 09-09-2013, 12:46
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
A large zip tie will soon become your best friend.
1058 PVC Pirates 2016 - xxxx
  #66   Spotlight this post!
Unread 10-09-2013, 22:24
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
I'm not sure why we haven't said this yet, but why not just use 118's original release robot? That could climb for 30, I believe it could score once at the top, FCS, cycle like crazy, had a quick ground pickup. Aside from being a tall FCS that was about as complete of a robot as you could get.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
  #67   Spotlight this post!
Unread 11-09-2013, 00:47
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
118's climb was to slow, unreliable, and hard to line up from what I heard. I am pretty sure they decided to focus on trips because of how easy it was for them to speed from end to end. They can make way more points with trips than with the FCS and climb. I also do not recall them being able to dump for 20 on top. Recently they have also been jamming and playing defense which was extremely odd. Any how, I do not see them the as the "perfect robot" but more as one of the most important parts to an alliance because of the ground feed and multiple trips.
  #68   Spotlight this post!
Unread 11-09-2013, 07:24
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Their shooter with the climber wasn't great. They took off the climber in order to put on a better shooter. They were shooting 2 or 3 out of 4 with the old shooter, and, well, you know how they were with the new shooter.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
