Go to Post Oh yes - and thanks for giving us kids our dreams. - DonRotolo [more]
Unread 09-09-2013, 12:54
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Andymark Performance Wheels: How Were They in 2013
This past year, Andymark introduced a new performance wheel using zip ties to attach the tread which was inspired by 971 IIRC. I've heard that 971 has used zip tied tread with much success over the past few seasons. I am wondering what teams who used the new style of Andymark wheels thought after a season of use. Some specific things I am wondering:
What wheel size were you using (4in, 6in, or 8in)?
What was the speed of your robot?
Would you characterize your team's driving as slower or aggressive (higher speed, quick acceleration, turning at high speeds, intense defense)?
How did the tread hold on to the wheel overtime? Any issues with tread coming loose or shifting?
Did the tread stay securely on the wheel until it needed to be replaced or did it come loose?
If adjusting loose tread was an issue, how often?
Did you noticed performance difference while driving in straight lines, pushing, turning, etc?
Would you use them again or make modifications to them?
Any feedback on your experiences with these wheels is much appreciated!
Thanks!
1058 PVC Pirates 2016 - xxxx
Unread 09-09-2013, 19:08
iyermihir iyermihir is offline
FRC #0649 (Saratoga MSET)
Team Role: CAD
iyermihir has a spectacular aura aboutiyermihir has a spectacular aura about
Re: Andymark Performance Wheels: How Were They in 2013
6in
8-9ft/s
fairly aggressive
We had to rivet them on as well because they kept coming off when we were pushed from the side
tightness was not an issue after we riveted
not an issue
no
yes
-Mihir Iyer
Unread 09-09-2013, 22:05
scottandme's Avatar
scottandme scottandme is offline
AKA: Scott Meredith
FRC #5895 (Peddie School Robotics)
scottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond repute
6" wheels - 6.5/15fps theoretical
4WD - 17.5" track length, 24.5" track width
Blue Nitrile tread
We had issues with the tread slipping off in our school hallways, and that's tighter pile carpet than the FRC field. Tried a few different zip ties (high strength, smooth body, etc) without much success. We kept using the zip ties to anchor the ends of the tread, but added 3 pairs of 1/8" rivets 120 deg from each other. No issues after that. It's a marginally better way to fasten the ends of the tread, but more work intensive to notch the tread to the right length and width.
Unread 10-09-2013, 17:26
JB's Avatar
JB JB is offline
FRC Kit of Parts Engineer
AKA: Jon Bryant
FRC #0238
JB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of light
4in
Roughly 10 ft/s
quick acceleration, intense defense, lots of use (3 districts/regionals, 1 district championship, 2 off-seasons - roughly 80 matches)
We also had to rivet our tread on due to treads coming off the rim of the wheel during high speeds and turning. We never had a failure with the zip-tie aspect of the assembly just with the treads sliding off.
Once riveted it stayed on till tread replacement was necessary
Not an issue once tread was riveted
Nope
Yes i think we will use them again and we will definitely be riveting the tread again.
As Scott said, the fastening of the treads is very neat, however it does not offset the effort of cutting and sanding down tread. We went through many zip-ties and pieces of tread in an attempt to get the tightest possible fit so that we would not have to rivet the tread on. All this work was useless as rivet was the easiest solution to keep the tread on.
Ultimately the wheels are great and I would recommend the hex fit to anyone, just be prepared to rivet the tread onto the wheels.
My posts are solely my own and do not necessarily reflect the views or opinions of FIRSTŪ or my affiliated team.[/center]
FRCŪ Kit of Parts Engineer: 2014-Present
Team 238: 2016-Present
Team 1403: 2008-2014
Unread 10-09-2013, 17:40
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
We used 4" performance wheels, but never used the zip tie mounting method. We put our own hole pattern on the wheels and riveted tread on the entire season.
Team 1538 / The Holy Cows, 2005-2016
Unread 10-09-2013, 19:02
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
We used 4" AM performance wheels in a 4WD wide set-up, powered by VexPro single-speed single-reduction 7:1 gearboxes with 3 CIMs per side. Sprocket ratio from the gearbox output to the wheels was 1:1 (34 tooth #25, if I recall correctly.)
We also purchased several rolls of 1" wide brown roughtop from Andymark, and held it on the wheels using wide-head rivets.
While the rivets held nicely, the roughtop tread de-laminated routinely when we were playing defense. 3 CIMs per side is a fun drivetrain; we were speedy, and were able to push many robots, but needed to replace tread after every match when we did so.
I really like the AM performance wheels but we will need a much more durable tread system if we use them again.
Richard Wallace
since 2003
Unread 10-09-2013, 20:38
cnepo's Avatar
cnepo cnepo is offline
AKA: Charles
FRC #0868 (TechHOUNDS)
cnepo is a splendid one to beholdcnepo is a splendid one to beholdcnepo is a splendid one to beholdcnepo is a splendid one to beholdcnepo is a splendid one to beholdcnepo is a splendid one to beholdcnepo is a splendid one to behold
We used AndyMark Performance wheels this season. We too drilled out holes to accept rivets into them instead of using the zip-tie method.
Configuration: 8-Wheel Drive (long)
Speed: ~6 fps low / ~16.5 fps high
Driving Style: Higher Speed, Quick Acceleration, High Turn Speeds
Tread Durability: We used a blue tread from a different provider (don't remember from where) and had minimum to no maintenance. By IRI, we just switched out center wheels to the outside and put new tread in the middle wheels.
Performance: Worked great, no loss of performance from the wheels all season.
Future Usage: Yes, we like the durability of the wheels themselves, but we would probably continue to rivet out the wheels to accept rivets as well as use the blue tread (because it matches our team colors too ).
Charles Nepomuceno
AndyMark Inc.
- Mechanical/Design Engineering Intern
FRC 868 TechHOUNDS (10 Years of FRC Involvement)
- Student: 2006-2010
- Mentor: 2011-Present
FRC 5010 Tiger Dyansty
- Mentor: 2014
https://www.facebook.com/FRC868
Unread 10-09-2013, 23:47
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Like the others on this thread, we found the regular zip tie mounting method inadequate. We ended up zipting the tread down to the rim of the wheel.
I suspect that if the tread was as wide as the slot and the zip tie didn't have to do a 90* turn to go into the hole on the wheel, it would have been much easier and stronger to put together. I hope we see a more 971 like design from AM, where the tread is quite wide and the zip tie runs around a central hub without twisting.
-Plutarch
Unread 11-09-2013, 00:25
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
192 used 971 style custom wheels last year.
3.5 inch diameter with tread 1.25 inch wide. The zip tie went in a groove around the hub so it didn't slip off. The zip-tie had to be pulled with pliers but we never had a problem with any tread coming off after driving practice, three regionals and champs.
Unread 11-09-2013, 14:48
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I know 1678 also machined custom wheels based on 971's zip tie method. From what I saw at champs, they were pretty close to what 971 ran, ~4" diameter and 2" wide. They were very happy with the performance, and made it to Einstein so they saw 2 regionals, divisional and Einstein play.
It seems that the AM wheels had some issue caused by either a tread Width/Diameter ratio, the wheel rim not having a big enough lip and/or the zip-tie attachment method not being as secure as the around-the-hub method 971 uses.
Unread 11-09-2013, 23:32
EagleEngineer's Avatar
EagleEngineer EagleEngineer is offline
AKA: Michael Amoun
FRC #1138 (Eagle Engineering)
EagleEngineer is an unknown quantity at this point
We used the 4in wheels, with blue nitrile tread, on a ~14 fps single speed gearbox from vexpro. And the treads would continually slip off, at the first competition we went to we added one rivet per wheel as well as the zip tie. And by our second competition we had 3 rivets per wheel as well as the zip tie.
2014 Colorado Regional Winners (Thanks 3310 and 2543)
2013 San Diego Regional Winners (Thanks 987 and 254)
2013 San Deigo Regional Entrepreneurship Award
2012 Los Angeles Regional Semifinalists (Thanks 599, 3309)
2012 San Diego Regional Finalists (Thanks 399, 2339)
2011 Los Angeles Regional Chairman's Award
2011 BAE Regional Judges Award
Unread 12-09-2013, 09:12
nuttle nuttle is offline
AKA: Allen Nuttle
FRC #4080
nuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud of
Has anyone tried a heat release epoxy? The idea would be to use this instead of rivets, here's a video that shows how you would get the old tread to come off: heat release. The strength before removal should be more than enough, going from the specifications. I'll bet there's an adhesive with properties that would match the requirements for this application very well, without destroying wheels.
