Go to Post Are you confused yet? - Andy Grady [more]
Unread 09-09-2013, 10:42
xmanrex123 xmanrex123 is offline
Junior Member
xmanrex123 is an unknown quantity at this point
robotics how to paper
ok i am writing a how to paper for my english class and i am doing it over repairing an andymarke super shifter gearbox mounted to the 2013 kit of parts frame but i need responses from frc team mentor for supporting evidence for the paper so i was wondering if anybody can help me and explain what is the easiest ways to detect and identify problems with in an andymark super shifter that has stopped working what would be my first steps of diagnostics so i can use this in my english class.
Unread 09-09-2013, 22:59
Junior Member
how to for gearbox's
Unread 09-09-2013, 23:15
Re: how to for gearbox's
I mean no offense by this, as English may be a second language for you, but even new members of Chief Delphi are encouraged to use proper spelling and grammar in their posts. While you don't have to write perfectly (heck if I ever do), on this forum, you will most likely get more replies to your questions if you write out your posts properly.
Additionally, please don't create multiple threads for the same question. http://www.chiefdelphi.com/forums/sh...99#post1290599
You can find a lot of information on Chief on this topic by using the search tool at the top. If you don't find what you're looking for, make a decently written post on here, with an appropriate title. Again, I'm not trying to be harsh, just letting you know what will yield better results.
Welcome to CD, I hope you find the information you're looking for!
Unread 10-09-2013, 15:05
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Re: robotics how to paper
I'm not sure if it is exactly what you are looking for but generally the easiest way to see that it is not working is if you notice your robot is not shifting. For example, if you shift from low to high gear and there is no noticeable speed change. Upon further, closer inspection you can check and see if the pneumatics are functioning properly (or servos?).
I would also assume that Andymark has something posted about this as well on their website and if it is not posted but they have it you could probably obtain it quite easily with an email. Since this is for an english class, it would also count as a direct source and would probably help your grade on this assignment.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 17-09-2013, 11:22
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Not sure if spam... but, if not, there are many references that you can find to see how the super shifter is made.
If you'd like to reference how the Super Shifter is built, here is a PDF containing the layout of the shifter itself. If you disassemble it and realize that it was assembled improperly, that could be part of whatever problem you're having.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
