Go to Post Here is one really important thing I learnt this season: If you do it for yourself, you ain't gonna make it. If you do it for you're team, You'll make it. - Bharat Nain [more]
Unread 11-09-2013, 14:58
TenaciousDrones's Avatar
TenaciousDrones TenaciousDrones is offline
FRC Team 4780
FRC #4780 (The Tenacious Drones)
TenaciousDrones is an unknown quantity at this point
Potentiometer Help
What would be the best type of potentiometer would be best to use? We have no use yet, we just want to get some so I can figure out how to wire and program them. If you guys could send me links to the ones you guys use that would be great.
Unread 11-09-2013, 15:21
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Potentiometer Help
For something just to play with, grab whatever is available at your local Radio Shack. You'll want to learn the difference between linear and logarithmic potentiometers (linear ones tend to be a little easier for the software guys to work with, for what we're doing).
Once you've got that down and know how to work with them, the rest is just going to your favorite on-line site (like digikey) and ordering exactly what you want for your needs. For example, you can get a potentiometer that has 270 degrees of rotation, with tops built in on either side. Or you could get one that has 360 degrees of rotation with no stops, so it basically repeats when you go past 360. Or you could get a mutli-turn which gives you many full rotations (this past year we used a 10-turn potentiometer... that means 3600 degrees of rotation to go from one extreme to the other).
Keep in mind that matching the rotation of the potentiometer to the actual rotation seen in your mechanism is important. If you have a mechanism that only turns 200 degrees, a potentiometer with a 270 degree rotation will give a signal output using most of the available range - in other words, in the code they'll see values across most of the range provided. If, on the other hand, you use a 10-turn potentiometer then most of the range is completely wasted. In this situation the difference of 0.1V could be a significant amount of travel for your mechanism!
For what it's worth, I have no part numbers for most of our potentiometers... we picked up an unlabeled bin full of used ones from one of our sponsors and sorted it by number of turns. It's good enough for most of what we do, and when we have something specific, we'll go to digikey and do some searches until we find something that fits.
2016: Lake Superior WFFA
Unread 11-09-2013, 18:05
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
My personal favourite is this (select analogue from the options).
Unread 12-09-2013, 18:21
DonRotolo's Avatar
Back to humble
FRC #0832
Oh, and pick a value of maybe 10kOhms. much higher and noise becomes a factor, much lower and too much current is drawn from your power source. The Radio Shack ones are just fine for 95% of what you'll be doing.
For a Digital Sidecar Analog Breakout, one outer leg of the pot goes to +, the other outer leg goes to -, and the center leg ("wiper") goes to SIG.
Last edited by DonRotolo : 12-09-2013 at 21:11. Reason: Aaron.Graeve is absolutely correct
Unread 12-09-2013, 18:37
Aaron.Graeve Aaron.Graeve is offline
FRC #1477 (Texas Torque)
Aaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to all
Last I checked, pots get wired to the analog breakout and not the digital sidecar.
Alamo, Bayou, and Lone Star Regional FTAA
2015:
Dallas, Alamo, Bayou, and Lone Star Regional FTAA
2014:
Alamo, Dallas, and Lone Star Regional FTAA
Alamo Regional Robot Inspector
2013:
Einstein Champion and 2013 World Champion (Thanks 1241 & 610), Galileo Division Champion, Razorback Regional Winner, Alamo Regional Semifinalist, Bayou Regional Semifinalist, Lone Star Regional Quarterfinialist
2012:
Curie Division Semifinalist, Lone Star Regional Finalist, Bayou Regional Winner, Alamo Regional Winner
Unread 12-09-2013, 21:10
DonRotolo's Avatar
Back to humble
FRC #0832
Yes, you are absolutely correct. I was thinking of a limit switch when I wrote "digital sidecar", but of course an analog potentiometer goes to the analog breakout.
