Go to Post It's not fair. it's not right, but stuff like this happens. If you don't get picked for finals tomorrow, get in those stands and cheer for those who did. Remember, this is FIRST. - wilsonmw04 [more]
Unread 13-09-2013, 13:49
Re: Drive Train Speed
Originally Posted by xForceDee View Post
how do I go about calculating theoretical speeds in high and low gear?
I understand the basics of gear ratios, so I guess the bigger question I have is the friction and weight factor.
So you want a theoretical calculation that includes friction?
Friction is highly variable and difficult to model accurately. It is therefore typically modeled with an adjustable parameter(s), whose value(s) are obtained empirically, and may be different from one drivetrain to the next, even if they are the same design.
However, if someone could run through the entire process, I think it would be very beneficial to other teams.
JVN's drivetrain speadsheet in CD-Media:
http://www.chiefdelphi.com/media/papers/2755 (2013 version)
http://www.chiefdelphi.com/media/papers/2059 (2008-2011 versions)
http://www.chiefdelphi.com/media/papers/1469 (2004 version)
Unread 14-09-2013, 10:45
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
Here's an Excel-based drive-train model. It allows the drivetrain parameters to be specified (including losses) and includes wheel slippage. The included paper provides the mathematical basis.
http://www.chiefdelphi.com/media/papers/2405
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
