Go to Post For example, you can make a car as safe as possible. It may get the highest safety ratings in it's class, but if you drive it off of a cliff there really isn't much you can do about that. - jmanela [more]
Unread 02-02-2003, 21:10
ROB at RAGE ROB at RAGE is offline
ROB at RAGE is an unknown quantity at this point
Drill Motor Mount Experence
Has anyone had problems with the Kit Motor mounts?
Theres been a lot of chat about the gear boxes and shaft couplings, but have not heard much about the motor mounts them selves.
We noticed that they are warpted and needed to clamp them down to a bench to measure shaft center line spacing and such.
Thanks,
Rob at Rage
Unread 02-02-2003, 21:15
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
They are very easy to warp be careful not to overtighten them.
Unread 04-02-2003, 22:39
Dick Linn's Avatar
no team (Synergy)
motor mounts
I understand that another Richmond, VA team (Tucker High ) tore up some mounts in practice. Someone else said they'd dropped one and it broke! As for us, we're being very careful not to overrtighten and are currently using rubber/soft plastic shims to take up the slack where the actual motor is held.
I do have one motor (drill gearbox) wobbling and need to determine if it is the aluminum adapter or the plastic hex adapter or a warped/misaligned mount. This is another common problem, I've heard.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 04-02-2003, 22:57
Maxzillian Maxzillian is offline
AKA: Eric H.
FRC #0935 (RaileRobotics)
Maxzillian is on a distinguished road
Send a message via AIM to Maxzillian
We have yet to have any trouble with the motor mounts, besides a slight problem of the gearbox rotating and breaking off a tab (put one heck of a load on it though). We now have the mounts cranked down, and have few problems. But we need to get some washers since the slots that the bolts rest on are starting to spread a bit.
Team 935 RaileRobotics Alumni: 2001-2004
Team 935 RaileRobotics Mentor: 2009-Present
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
A new record for breaking a drill motor ZacharyD Technical Discussion 23 16-01-2003 16:58
