Go to Post A lot of people forget this when posting, but your posts here on ChiefDelphi will more or less be here forever. Do you really want that post you just be made to be on the Internet forever?... Post wisely... - artdutra04 [more]
Unread 03-02-2003, 18:40
adambarnett adambarnett is offline
adambarnett is an unknown quantity at this point
Team 364 Near Completion(With Pics!)
Our Robot is very near completion. The highlights are a fully functional two speed transmission, allowing us to switch gears on the fly from 9.8 ft per second high gear, to a 5 ft per second low gear for pushing. We also have four suction cups positioned on the bottom of our robot to allow us to stick to the HDPE and a box bashing arm. We plan to be 14 inches tall to allow us to fit under the bar. Here's a pic(minus the suction cups, I'll post an updated picture later). Check our our website for more information and pictures.
Unread 03-02-2003, 19:12
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Nice. I really like the tires.
Just wondering, is your favorite game on your team Metroid FUSION!?!?!?
Unread 03-02-2003, 20:14
I don't get it?...
Unread 03-02-2003, 22:54
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
A quick note about those tires... We used the same ones last year. We noticed that on the carpet, they don't have a whole lot of traction. (Well...they do...but you can get more) Wear them down a little so you have more surface area and make perpendicular grooves in them (so you have some nice 90-degree angles). To make the grooves, we duct-taped three hacksaw blades together and sawed down each grove. We had a noticeable amount of gained traction. Just a thought (Grooves will also help a lot on the mesh, too)
Maybe you already had plans to modify the tires...or not. But this goes to any team that has never used these wheels before or would just like to get a little more out of them (We ditched these wheels for the wider ones )
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 03-02-2003, 23:04
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
We used those tires last year too, we cut grooves like evulish said and they grooves worked great,
to lose some weight you can mill out the part of the wheel in between the outside and the hub, be sure to go around the bolt holes, just pull the two pieces apart off of the rubber and you can cut it with a jigsaw. It will cut out about 25% of the weight.
Unread 04-02-2003, 08:23
Yea we did something similar to the wheels last year. We actually ended up attaching breckoflex to them, it worked pretty well.
Unread 04-02-2003, 22:41
Wink
We now have some videos up if you guys want to check them out
Unread 04-02-2003, 22:45
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
*krrrschhh* *plop plop plop.. plop* very nice attachment mechanism
Unread 04-02-2003, 23:01
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Suction cups= awesome
in the video it looks like all four wheels are lifted off the ground- does this actually happen? I seem to remember a rule that says you can't do that.. hmm- looks in rule manual
Unread 04-02-2003, 23:08
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
very cool. Looking at your light, unless it raises itself, it is only visible from one side, the top. Unless im just an idiot and going blind.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 04-02-2003, 23:20
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Definatley a very cool robot. If you take a look at all the videos the light seems to be retracted into the body in all but the suction video. Since they only need the light down while getting under the bar, I'm sure the reason they kept it retracted is because of how annoying it is ;o)
Unread 05-02-2003, 08:29
yea the light goes up and down so we can get under the bar. The suction cups lift the whole robot off the ground... I don't think it's against the rules?
thanks for all the comments!
Unread 05-02-2003, 09:09
I looked through the rules and I couldn't find it. That rule wouldn't make much sense either...lifting your robot up is no big deal, and plenty of teams are going to have suction cups....
Here's another picture:
Unread 12-02-2003, 12:20
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
We were going to use suction cups.............. but we found a major problem...........
If there are scratches in the surface of the ramp, they don't work. I would make sure that yours works just in case.
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
