Go to Post I, for one, am perfect and therefore make no mistakes. (Unless you count all the times that I completely screw up) - Molten [more]
Unread 17-09-2013, 21:04
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Re: Coasting Problems
Just for future reference, my favourite deadzone code looks something like this:
float deadZ (float val) {
	return val > 0.6 || val < -0.6? val: 0;
Then you would simply say something like 'tankDrive(deadZ(leftStick), deadZ(rightStick));'
To me this is the most aesthetically pleasing. But to each his own :P One thing I noticed that would also make it look better (my apologies, I'm really picky about these things) would be to assign 'Hardware.leftJoystick.getRawButton(1)' to a boolean somewhere in the beginning of your code so that you don't have to type that mess every time you need to check it. You could also make a similar method to the one above that takes your boolean as an input as well as a joystick value and clean up the code even more (there's currently a lot of code involved in just getting it to drive). Just my $0.02 :P Take it with a grain of salt
Unread 17-09-2013, 23:12
Matt_4505 Matt_4505 is offline
FRC #4505
Matt_4505 is on a distinguished road
Thanks, I will definitely give those a try.
