Go to Post The FIRST community will always step up in times of need. - nikeairmancurry [more]
Unread 18-09-2013, 03:28
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Need Help With Sheet Metal Designing
JT, We just started using sheet metal last season. We have a laser cutter sponsor so it's easier for us than it will be with you and the mill (remember to fillet your corners to the size of your end mills).
Here is the presentation I put together for the team last season when we decided to start doing this. It's definitely not complete and I was learning at the same time so I don't make any promises that is all correct but it will get you started.
https://www.dropbox.com/s/63ke4hzitw...t%20Metal.pptx
I would also recommend looking at the CAD files and robots from teams that do sheet metal well, 33, 148, 228, 1114, etc.
My favorite is still 148's 2011 Robot Raptor. I have a whole presentation that I go over with the team that is just on this robot.
Here is an interesting read on doing different types of 2D manufacturing (sheet metal, CNC routing, etc) for building things . http://www.instructables.com/id/How-...y-Really-Fast/.
Also go back through and read the threads on other people's designs. Some really smart people, give really helpful advice. Here are a few of the recent threads. 1114 Inspired Chasssis, 488 Fall Project 1 and 2, Sheet Metal Drivetrain Prototype and there are many more like it.
Unread 18-09-2013, 04:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I'd recommend filleting the corners to larger than the size of the end mills, even if just by a little.
Unread 27-09-2013, 18:10
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Do you mind if I use this presentation with some modifications to help with training our members? (I will give you guys credit at the end of the presentation)
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 27-09-2013, 18:31
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Our team uses aluminum 1" box tubing for our frame, which we temporarily attach somehow (I dont remember?) before having our sponsor (one of their employee's who does nothing but weld aluminum all day) weld it all up nice. This year's frame was far too complex, but it came in at just 13lbs and is stupidly strong (could probably withstand 1,000s of lbs of force in any direction). It also is easy to work with, has nearly infinite practical durability and is very rugged. We subsidize this tubing with sheetmetal for more robot subsystems (shooter, drivetrain assemblies, ramp lowerers, innertube grabbers).
We typically use 1/8" alum (powder-coated of course) for heavy systems like drive train and climbing brackets, and 1/16"-.0404" for shooters and such. We used .0202" (basically IS paper) in 2011 on our gripper because if it got banged up, it was super easy to hand-bend back into shape.
Unread 27-09-2013, 18:44
Andrew Lawrence
Posts: n/a
You should try working with 1/2"-3/4" 1/6" wall steel. It's strong, light, and easy to weld!
Unread 28-09-2013, 11:35
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Do you mean 1/2" square tubing (or 3/4" square tubing) 16 gauge steel? Or do you mean a different gauge steel?
- T
-T
Unread 28-09-2013, 18:44
I am Dave! Yognaut
AKA: Brian Bray
I think he means 1/2"x3/4" rectangular tubing with (im guessing 1/16" not 1/6"?) 1/16" wall thickness
Unread 13-10-2013, 02:06
JTN's Avatar
JTN JTN is offline
AKA: John Taylor Novak
FRC #0016 (Bomb Squad)
JTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond repute
Aaaand the results:
They say I can't use a URL or BB code, so I'll use this for my signature.
Unread 13-10-2013, 02:12
I am Dave! Yognaut
AKA: Brian Bray
Cool stuff! how much does all this weigh?
Unread 13-10-2013, 20:51
JTN's Avatar
JTN JTN is offline
I'm not sure yet, but I'll keep you posted.
Unread 13-10-2013, 21:18
AKA: Jesse Gibson
Team Role: CAD
Looks pretty awesome so far, although I do have one question/concern. Had you planned to add a belly pan? Though I will be the first to admit that my knowledge of sheet metal design is still very much a work-in-progress, it would seem that without one there would be issues with rigidity so if you hadn't planned to add one, I would recommend it.
2011 - Logomotion
Unread 16-10-2013, 11:00
JTN's Avatar
JTN JTN is offline
This drawing is to show the frame itself. There will be a belly pan on the actual robot.
Unread 16-10-2013, 13:43
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
JTN,
Think when you get to the assembly stage how hard to get your frame square with the current design. Think about the process to get the frame built and how to adjust/replace the swerve pods. Which parts are put together first and assembly to each other?
A example would be to built 2 each of two mirrored swerve modules. Test the swerve modules motors and steering independently of the frame. Assemble to frame.
The frame is what holds the swerve modules nice and square. It looks like there are a lot of pieces that have to mate together and be square and strong, lightweight. Consider using one piece of metal for the frame and bending it into a box structure. The hole to hole tolerances with be higher than multiple pieces assembled together and you will find that bending the piece will make the frame stiff and square.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 16-10-2013, 14:24
AKA: Jesse Gibson
Team Role: CAD
That's what I figured, just wanted to double check
2011 - Logomotion
Unread 27-09-2013, 22:01
Engineering Coach
Feel free, I hope it helps.
